Is my Clutch on the way out?
Postby Gareth » Sat 30.04.2011, 12:40
Glorious day, top down, dual carriageway, foot down, overtaking a Hyundai Coupe : so far so good!
Turbo kicks in, boost shows 0.8 (old BBS upgrade), rev counter shows 5 - 6,000 RPM, I smell burning, the Hyundai Coupe driver laughs, I pretend i never really wanted to overtake!
Is this the clutch slipping and means a new clutch?
If I drive "normally" everything is OK!
If it needs a new clutch, is it straight to Lotus or are there other clutch suppliers/manufacturers that will fit?
If I'm replacing the clutch would it make sense to replace the cam belt also? (low mileage but not replaced for 3 -4 years)(car is 1991 SE)
All help/advice appreciated.
:bonk:
Gareth
Gareth
Re: Is my Clutch on the way out?
Postby Specky » Sat 30.04.2011, 13:17
A quick an easy trick...
Park the car up, Put the car in 5th gear and try and drive off gently. If you go nowhere and it doesn't bite it's a sign.
With a good clutch you will smell burning a bit, but it will take you up to the speed limit.
Have a quick search on the Internet for more info...
I would't bother with another cam belt change.
Don't forget Rockauto in America for Isuzu parts, much cheaper than Lotus.
Spares normally take about 5 days.
Make sure you get a clutch/ thrust/ pressure plate for a turbo, not the N/A clutch
Isuzu impulse RS
Postby RayD » Sat 30.04.2011, 20:58
Another version of Dave’s trick is to stop the car from moving altogether and let the clutch out slowly … the engine should instantly stall.
If you can run the engine, in gear, with the clutch engaged and the car stood, it wants a new clutch.
Postby addict » Mon 02.05.2011, 23:13
find the biting point then work out how much more travel the pedal has . will tell you something
addict
Postby Gareth » Tue 03.05.2011, 07:40
Thanks guys!
Yes, I think it's the clutch!
Been on the "Rockauto" site : seems like 5 to choose from : any advice on which one to order?
Gareth
Gareth
Postby bobbrown » Tue 03.05.2011, 09:01
Personally I would opt for the Sachs clutch as they are a good brand part of the ZF group who make gearboxes, not sure that it would fit mine as it has a smaller clutch as its a NA.
But it's your choice or you could go uprated
Pacific Blue N/A
