Changing Transaxle Oil, Speedo Gear
Postby ccb056 » Sat 14.04.2012, 20:06
I'm following the procedure here and have removed the coolant tank.
I am looking for the speedo gear
Is this it?
ccb056
Re: Changing Transaxle Oil, Speedo Gear
Postby HJ2 » Sat 14.04.2012, 20:11
Yeah, you found it! :clap:
remove the bolt to the right of the red circle only, and you can pull it out!
Postby RayD » Sat 14.04.2012, 20:21
Here's the picture from the manual ...
Postby hatters » Sat 14.04.2012, 21:14
What are you going to use to get the oil in the box
The reason I am asking is I think I should havea go at mine soon
hatters
Postby muley » Sat 14.04.2012, 21:54
I got a length of clear plastic tube about 10mm dia I think from my local aquatic centre - stuck a funnel in it and poured away....
p.s. Do not overtighten the bolt - it might shear - the manual only calls for a few ft. lbs.
Postby Steve A » Sat 14.04.2012, 22:59
That would be 10mm internal diameter or you may be some time waiting for it to fill up :lol:
I measured the exact amount that came out, to check to see if I had a leak,
and then poured in the required amount stated in the manual, which in my case was the same :D
Postby muley » Sat 14.04.2012, 23:35
I'll measure it tomorrow or sometime soon, matey. Whatever it was it did the trick
Postby ccb056 » Wed 18.04.2012, 21:02
hatters wrote:What are you going to use to get the oil in the box
Once I get the new alloy radiator and hoses installed I'm going to use a hose with fitting purchased at Walmart and funnel to get the oil in. The hose fitting screws into the oil bottle so the mess should be minimized.
ccb056
Postby ccb056 » Tue 08.05.2012, 05:27
Drained the old oil and put in GM 12346190.
Running good now. The job took about 2 hours. With the right extension bar and pivoting joint it isn't too bad to get to that bolt.
ccb056
