Stuck in first gear...
Postby questel » Mon 04.08.2014, 22:50
Hi all,
pulled out today and no sooner than I shifted into first gear the car became stuck in first gear. I cannot get it out of first gear. Does this mean I've broken the linkage cables?
questel
Re: Stuck in first gear...
Postby epipete » Mon 04.08.2014, 23:35
Simple way to check is to have someone move the gear stick whilst you look at the top of the gearbox (remove the coolant tank out of the way first) to see if the levers are moving!
Postby questel » Tue 05.08.2014, 00:45
Will do. First thing when I get off work tomorrow. Thanks
questel
