joint caps
joint caps
Postby pietro » Thu 05.12.2024, 14:13
hi. where can i buy the half shaft joint boots? i cant find them... thanks guys
in the desert only the Bedouins and the Gods feel at ease.
And you, Lawrence, are none of these
pietro
Re: joint caps
Postby Tuga2112 » Thu 05.12.2024, 14:38
are you talking about this kind of stuff ?
https://www.amazon.co.uk/febi-bilstein- ... 122&sr=8-3
Re: joint caps
Postby muley » Thu 05.12.2024, 15:11
If it's a CV boot you need, they're obtainable from SJSports
I tried a split boot it didn't,'t work
Alternative suppliers weren't much help either
Re: joint caps
Postby Tuga2112 » Thu 05.12.2024, 16:10
yes, im not sure either if we are talking about CV boots or something else.
but to elaborate a bit more.
i have seen people mention they used the "glue 2 halfs" types and had great results.
I buy mine from J&R specialist. and i get the universal fit stretch ones. (not the 2 half type) they work in every scenario. and you just need to trim the excess after fitting. the only issues i had were always a result of poor instalation when the "circlips" dig hard into a ridge of the rubber.
all in all.. your mileage may vary
Re: joint caps
Postby pietro » Fri 06.12.2024, 08:20
Tuga2112 wrote:are you talking about this kind of stuff ?
yes
pietro
Re: joint caps
Postby pietro » Fri 06.12.2024, 08:21
thank you all
pietro
