Any cross-reference on CV Joints?
Postby Fubar1764 » Sat 19.11.2005, 16:13
Noticeable clicking in reverse, but only under load (i.e. engine on). This means it's likely to be a CV joint that needs replacing.
Wondering if the CV joints are available from other makes/models?
-Your "Jack" of all trades
Fubar1764
Postby Doc Fizzix » Sat 19.11.2005, 18:21
Does this mean you are driving your car again? :D
I am not sure but since I have had to change mine on both my Elan I am very familiar with this part. I have been looking at the Isuzu and Geo drive shafts and they look identical. I have not really tried replacing on with an Isuzu but at least the ends look the same. If the shaft is a different length then it is a easy "swap"
Doc Fizzix
Postby Fubar1764 » Mon 21.11.2005, 15:08
She was never off the road, just a bit of road rash from a dumb kid. After a bit of threatening, insurance is finally getting their act together.
Fubar1764
Postby Doc Fizzix » Mon 21.11.2005, 20:38
Does not sound like the "ding" was to bad then :D
Check the Isuzu drive shafts on eBay right now, there are a bunch and cheap.
Doc Fizzix
Postby Doug » Tue 22.11.2005, 00:43
I though Jack told me the guy took a chink out of the front . . . :lol:
Postby Doc Fizzix » Wed 23.11.2005, 06:34
A "chink" ? :?
That does not sound good :shock:
Doc Fizzix
Postby Fubar1764 » Thu 24.11.2005, 09:07
Doug wrote:I though Jack told me the guy took a chink out of the front . . . :lol:
:lol:
Fubar1764
Postby Doc Fizzix » Sat 26.11.2005, 03:06
come on Jack, post some pics :D
Doc Fizzix
Postby M100 TWO » Sat 26.11.2005, 18:13
Hardy Spencer Drive Line part no DL1833 (400 300)
check out these numbers with Hardy Spencer A087 03 091 EA AEG6 92 0509 B it might throw up what we want
M100 TWO
CV Joints
Postby DAdragna » Sun 07.05.2006, 02:34
I looked for a bit but was un-able to find any information stating what
Isuzu / Geo CV joint will work as replacement for the M100. My passenger side outer boot split sending a greasy mess throughout the wheel well and inside the wheel.
Any thoughts on whether I should replace the half shaft or just put two new boots on? (Inner / outer) the car has 48k on it and there are no noises out of the cv joints. I think probably just replacing the boots is the way to go. Are the boots a standard sized item? I have never worked on cv joints before. Does anyone have a part number for Isuzu / Geo axle boots? Also, are the split style boots acceptable to use? :?
Thanks,
Dan Adragna
DAdragna
Postby TommyK » Sun 07.05.2006, 03:43
The manual has some good stuff about this... it pretty much says that just as long as you don't get any abnormal noise/vibration doing just the boots should be okay. I ran this by my Lotus mehcanic when I had a booboo and he totally agreed. The boots straight from Lotus weren't that expensive (<$50) if I remember correctly.
TommyK
Postby Doug » Sun 07.05.2006, 05:19
I put a split boot on one of mine and it has been fine.
After all it's only a freaking boot to hold the grease in -- why pay a king's ransom. I'd rather put 10 split boots on over the years than pay 20X as much and all the labor to put on an OE boot.
I remember someone got a boot that they used that was the same size and I'm thinking it was a Honda or something like that?? It was in the Forum a while back . . .
Just get a caliper and measure the diameter of the 2 ends and go find a boot to fit.
Postby Candles » Sun 07.05.2006, 07:59
Yeah but you don't drive yours in the wet!
Candles
Postby Doug » Sun 07.05.2006, 08:33
Candles wrote:Yeah but you don't drive yours in the wet!
wait a minute -- I don't drive it at all :?
Driveshaft and Boots
Postby johnbenk » Sun 07.05.2006, 16:40
Hi
The boot is off a vauxhall. there is a thread with a part number on parts cross reference .A boot made by a company called Shaftee will fit.
johnbenk
The only Gay in the Village
Postby Exbury » Mon 08.05.2006, 09:55
There are instructions somewhere on this site, it might be from the main page about how to change a CV boot using a split boot. Most importantly;
1-If the boot has split stop driving the car, you might lose all grease and kill the CV joint.
2- If the CV joint is making any noise it needs replacing (imagine it coming apart at full speed going around a corner, first the wheel comes off.......), if the joint isnt making a noise it should be ok.
3 - follow the instructions carefully (I think Sy wrote them), most importantly clean ALL the old grease away, and I mean ALL. 1st time I did a split boot on a renault I left a bit of grease on there, it got on the boot join and the boot split rapidly afterwards.
4 - Sy, I and several others have done split boots on the Elans, do them properly and you dont have to take much apart and they are far easier than whole boots. Mine has not been a problem and past an MOT without a hitch. I was lucky though, I spotted mine just starting to split as it went for a new exhaust.
Forgot to add, whole kit is around £15 from a parts dealer, I think I got mine from Brown Brothers who are in Bishops Stortford near you.
Exbury
Boot replacment
Postby johnbenk » Mon 08.05.2006, 14:22
Hi
There is any "easy" way to replace the "boot" that does not involve taking apart the suspension.
Disconect the bottom ball joint and steering joint after removing disc brakes etc.
The shaft will hang loose and the boot can then be removed leaving the suspension untouched (steering angles etc caster,cam)
DO NOT FOLLOW LOTUS INSTRUCTIONS
Time taken less that 1 hour.
johnbenk
Postby DAdragna » Tue 09.05.2006, 02:27
Great information! I appreciate the input. I will put off the repair for about a month due to work...so until then she will sit.
While I am in that area, I will put the brake up-grade kit on (that has been sitting in the garage).
Thanks again!
Dan Adragna
DAdragna
Re: CV Joints
Postby Doc Fizzix » Tue 09.05.2006, 04:47
DAdragna wrote:My passenger side outer boot split sending a greasy mess throughout the wheel well and inside the wheel.
Now you are truly becoming a veteran Elan owner :D
Do the job yourself and the boot will be good for another 80K
Doc Fizzix
Re: CV Joints
Postby DAdragna » Tue 09.05.2006, 23:13
Do the job yourself and the boot will be good for another 80K[/quote]
I need to become a veteran Elan owner.....I keep putting off the work I want to do on the car. :x I will definately get into it by June! :D
Dan A
DAdragna
