GEAR BOX SELECTOR
GEAR BOX SELECTOR
Postby sonu » Sat 24.06.2006, 21:35
hi desperate cry for help here... :cry: does anyone know where to get the outer casing on the gear shift cable as that is all thats broken on my elan. However, i dont need all the cable, only the case where the circle sits on.
any suggestions will help
thank you
can you e-mail me if you know where I can get it from.
(sar1_sonu@hotmail.com)
cheers
Sonu
sonu
Postby Enright » Sat 24.06.2006, 22:04
That's the classic failure point, and the answer is no, I'm sure that you have to buy a complete cable. And even if you didn't, there's no way to get the outer off the inner bit as the ends are swaged on.
Postby muley » Mon 26.06.2006, 08:42
Sonu,
...and if you are replacing them you might as well buy some AB cables - they'll probably never need replacing again as they are extremely solid and well made.
Postby sonu » Mon 26.06.2006, 12:28
ok does anyone have an old cable, im willing to buy.
cheers
sonu
sonu
Postby Monty » Mon 26.06.2006, 15:30
Sonu,
I have a set off SE cables up for sale for £50 if u`r interested. I`ve also got one single cable the other one broke, which was has gone on u`rs?
Ps where are u based?
Users browsing this forum: AhrefsBot and 1 guest
