Hi.
about the shifter's free play. how can it be improved?
Please advise.
Cheers,
John_W wrote:Even with the changes mentioned above, there is still some slop in my gear-lever. It comes from the white nylon bush into which fits the extension which controls the "left-to-right" movement of the gearchange (arrowed). The nylon has presumably worn over the years.
I don't suppose anybody knows if this part is available?
Dave also mentioned a while ago that he was experiencing sloppiness caused by wear in the white nylon cup around the ball-joint pivot of the lever (also visible in the picture I've nicked from Enright13). I think he said this part was not available.
kmckmc wrote:In my S2, I replaced a new shifter assembly, and the shifter's free play did not improve. Please note my S2 still has the original gear cables. But I do not really think that by replacing new cables, the situation will help.
So, I suppose, there is not much we Elan M100 driver's can do.
