Vibrator
Vibrator
Postby GeoffSmith » Sat 10.05.2014, 18:48
Well oscillating multi tool actually…
Compared to an angle grinder, it's more manageable in tight situations, generates a lot less heat and no sparks.
Re: Vibrator
Postby Tuga2112 » Sun 30.11.2014, 20:10
why not a dremel instead ?
Re: Vibrator
Postby Megwenda » Sun 30.11.2014, 20:34
Tuga2112 wrote:why not a dremel instead ?
Well, as Geoff says,
GeoffSmith wrote:Compared to an angle grinder, it's more manageable in tight situations, generates a lot less heat and no sparks.
And a Dremel is in that sense also an angle grinder.
I have a similar tool (the fein multimaster tool, from which the Bosch etc are copied), and use both it and the Dremel regularly, but each has its strengths and its weaknesses.
Megwenda
Re: Vibrator
Postby HJ2 » Sun 30.11.2014, 21:43
Fein rules! 8)
Re: Vibrator
Postby epipete » Sun 30.11.2014, 21:46
Ok, so how does it work? I assume it oscillates from side to side in a small arc and effectively saws through whatever you are cutting.
How much vibration is there, and is it maneagable, ie what is the risk of slipping and cutting a big hole in your fibreglass?
Re: Vibrator
Postby Megwenda » Mon 01.12.2014, 07:34
Yup, moves at very high speed in a small arc.... but does more than just cut as there a a wide range of attatchments
Very manageble, virtually no vibration, and no kickback.
I have the Fein here in Switzerland for general use, but also have a bosch one at my holiday cottage in Ireland which I use for the odd job... The Fein is better, but also much more expensive... worth it if you are doing a lot of hard work with it
There is also a Dremel version if you want to stick to one maker, but I have no exoerience with it.
Some info found HERE, and a comparison HERE
Megwenda
Re: Vibrator
Postby epipete » Mon 01.12.2014, 09:19
Interesting, my conservatory is made of wood and I noticed some early rot, I wonder if this might be the tool I need for cutting it out!
Re: Vibrator
Postby Tuga2112 » Mon 01.12.2014, 20:43
my dremel set (from maplins) came with an extention cord, i find it very handy to grind tricky places (like recently rusted screws that old the weather seal) and as far as vibration is concerned i find it perfectly manageable, can you give me a couple of examples where this would be considerably more suited than the dremel ?
Im keeping an eye on tools at the moment as i have found out that some of the tools that i never had any interest in buying (like the dremel) turned to be extremely usefull, thats why im wondering if this is one of those, or more of a tool that is only ideal in a very specific scenario
Megwenda wrote:Well, as Geoff says,
I use the small cutting discs on the dremel, am i doing it all wrong ?
Re: Vibrator
Postby epipete » Mon 01.12.2014, 20:46
I'd suggest the chief advantage would be that you can 'attack' the job from a better angle, oh, and you're not forever changing broken cutting disks.
Re: Vibrator
Postby Brit-Car-Nut » Mon 01.12.2014, 21:16
With the Multimaster, the movement of the blade is almost imperceivable but it cuts, sands and grinds extremely well.
Pete - it is great for surgically cutting out sections of damaged or rotted wood and is amazing at cutting drywall or sheetrock. You can have a helper hold up a thin board to use as a fence and it just buzzes through with absolutely minimal dust blowing around. There are a lot of different blades available for ripping, plunging, grinding and sanding.
In the US there are at least 5 different companies selling something similar but the Fein is still the best. The cheapest copy is available from Harbor Freight for around $19.00.
They have cutting blades for almost any material and like the picture Geoff provided, it cuts small bolts very well without having a blade or disk getting hung up on other bits.
For a review and to see it used look here: http://www.youtube.com/watch?v=l018VOrD7as
I have a Fein and a pile of blades and a couple of the Harbor Freight ones for crappy jobs or friends to borrow.
Re: Vibrator
Postby Jeemy » Wed 03.12.2014, 13:25
Also great with a wide flat blade to take off old underseal/gunge.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Re: Vibrator
Postby lotos » Wed 03.12.2014, 15:48
I had the Harbor Freight one but it broke on me within a week. Then I bought the Makita cordless that goes with my LXT tool set and really like it.
I used it last week to reshape the back of my bookcases to go around the baseboard so they fit snugly against the wall. Went through the wood like butter.
lotos
Re: Vibrator
Postby Ian T » Thu 04.12.2014, 10:15
Looks like you have the battery version Geoff, mine must be older. I bought mine for lifting floorboards and cutting out plaster before sinking the metal back boxes into the walls for mains sockets etc.
Quite simply one of the best power tools I ever bought - Bosch PMF 180 E
Ian T
Re: Vibrator
Postby Ade » Thu 04.12.2014, 13:07
I have one of these also, but just a cheap version. Don,t know how I managed without one.
Ade
Ade
Return to Tools
