by ailwyn » Sat 05.01.2008, 23:15
If I have a threaded fastener, how do I know what size it is if I can't find it documented?
I've come across thread gauges which could give me the pitch, but how do I know if it's an M10, M8 or whatever other variation?
- Forum Member
by GeoffSmith » Sat 05.01.2008, 23:18
M8 is 8mm across the thread. M10 is 10mm across the thread.
- Kitty Fiddler
by ailwyn » Sat 05.01.2008, 23:42
and does the length go from the bottom of the head to the tip or the full length of the bolt, or the length of the thread?
- Forum Member
by nitroman » Sat 05.01.2008, 23:58
The length is from the bottom of the head to the tip of the bolt, whether or not the entire shaft is threaded. It is perhaps simpler to say, measure the shaft only.
nitroman
by GeoffSmith » Sat 05.01.2008, 23:59
Bottom of the head to the tip.
- Kitty Fiddler
by ailwyn » Sun 06.01.2008, 00:02
Thanks both.
- Forum Member
by algirdas » Sun 06.01.2008, 06:00
Dear Ailwyn:
Check out this web page and the links contained in it.
http://www.boltdepot.com/fastener-infor ... eners.aspx
Real basic how-to stuff on measuring bolts and nuts.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
by ailwyn » Sun 06.01.2008, 11:43
algirdas wrote:http://www.boltdepot.com/fastener-information/Identifying-Fasteners.aspx
Highly recommended for anyone as bemused by fasteners as I am.
- Forum Member
Return to Tools
