Head Gasket - Block Tester instructions
Postby dans » Wed 02.04.2008, 22:41
Hi all,
Got a possible suspect head gasket, as per this lotuselancentral.com/forum/viewtopic.php?t=11991&start=0
I've now got some Tester Fluid but no instruction on what to do with it.
Can anyone give an idea of what quantity of Tester Fluid to mix with what quantity of Coolant.
Any more info and tips much appreciated!
Cheers,
Dan
dans
Postby Monty » Wed 02.04.2008, 23:38
Dan
i seen them do it on Pinky but don`t know how much fluid they used :?
Are there no markings on the unit?
At the garage it looked like it was filled roughly to half way (there must be an indication mark) then placed over the expansion tank then sqeeze the bulb to draw in some air then wait for to see if it changes colour :? and i`m sure the engine was running at the time :?
Think Da-Pinky would be the man to ask, there must be some type of instruction on the net :?
Postby dans » Thu 03.04.2008, 08:49
Thanks Monty, strangely haven't been able to find anything on the web yet.
I've only got a bottle of the fluid, not the actual bulb thing!
Dan
dans
Postby dans » Thu 03.04.2008, 09:17
Did find some useful info, but not detailed
http://www.arrowheadradiator.com/head_g ... k_test.htm
http://www.arrowheadradiator.com/preven ... ilures.htm
Guess I still need to find myself a bulb!
dans
Postby Monty » Thu 03.04.2008, 10:49
LOL
Yeah you need the full kit :lol:
So it does look like you have the car running and up to temp
Postby Gazza » Thu 03.04.2008, 11:51
Monty wrote:
So it does look like you have to have the car running and up to temp
I remember Sinclaires telling me this at Donington.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby muley » Thu 03.04.2008, 22:55
Dan,
I've got a 'bulb' you can borrow if you want.
I'm in Wokingham
Postby dans » Fri 04.04.2008, 08:36
Thanks for the offer Jim but I suspect I should just stop being tight and get my wallet to get my own!!
Cheers,
Dan
dans
Return to Tools
