by Elanlover » Fri 07.11.2008, 14:45
Since I doubt I could fit an hydraulic lift in my garage I was thinking about
4 of these. Standard axle stands give you only about 20" of height. These look like you could get over 3 feet making it easier to do just about anything under the car. They might get a little close to the body so I'd need to take some measurements but anyone have any thoughts on practicality, safety or the like?
by Sy V » Fri 07.11.2008, 14:46
B
The link's a no-goer for me, sorry.
- LEC Godfather
by Elanlover » Fri 07.11.2008, 16:06
Seems to work for me. Sure you aren't screening out Canadian websites
by Sy V » Fri 07.11.2008, 16:12
It's not beyond the realms of possibility that my
American corporate firewall may be doing something of that kind. Just in case, and for your info it takes me here:
http://www.canadiantire.ca/welcome.jsp; ... 6070603097Some Canadian site that insists on the input of a Canadian Post Code.
- LEC Godfather
by donsladek » Fri 07.11.2008, 16:16
Elanlover -
I used to own one of these when I had my Nissan Patrol 4 X 4. Potential issue using them on the Elan:
-The handle length requires a lot of working room
- The base is relatively small - a plus if you're tipping a 4X4 off of it to get unstuck, but not very stable for working underneath, you would need to add a larger base for stability.
- I think you would have to extend the lifting "arm" to prevent contact with the body.
- mating to the jack points will be an issue.
My assessment - it would take a lot of additional work/fixturing to use these, and they only rise about an inch per jack cycle so the lifting process would be real slow.
Don Sladek
Calypso Red '91 #37594
donsladek
by Elanlover » Fri 07.11.2008, 16:16
Grrrrr.......frickin' Canadians. Sorry Sy, if you don't mind typing in M9B 5P3 it'll take you directly to the page.
by Elanlover » Fri 07.11.2008, 17:27
donsladek wrote:Elanlover -
Was a bit concerned about the base actually. And, I do think the arm is a bit short
Oh well,
this might be a better idea.
Return to Tools
