Flexible shaft hose clip driver
Postby GeoffSmith » Fri 09.05.2014, 13:07
Wow. :smt049
Re: Flexible shaft hose clip driver
Postby Rusty Wishbone » Fri 09.05.2014, 19:37
There is a tool for every operation. I love flicking through catalogues from Machine Mart and Frosts trying to identify what all of the items are for. Sometimes you come across a tool that you simply must have. But this isn't one of them.
Rusty Wishbone
Postby GeoffSmith » Fri 09.05.2014, 21:52
You've never been lying on your back trying to get to to the hose clip on the top of the intercooler that someone has put on at the most outrageous angle then Howard?
Postby Rusty Wishbone » Fri 09.05.2014, 22:07
Not yet. But I have 3 boxes full of Samco hoses waiting for me... to buy a long-reach hose clamp fastening tool.
[ps - can't you just use a long screwdriver?]
Rusty Wishbone
Postby Brit-Car-Nut » Fri 09.05.2014, 22:58
Rusty Wishbone wrote:Not yet. But I have 3 boxes full of Samco hoses waiting for me... to buy a long-reach hose clamp fastening tool.
You will learn a whole new vocabulary when you start changing the hoses. A screwdriver is great if access to the tightening head is a direct shot. When it is 90 degrees around and completely blocked by other components, a flex shaft is the only way to get to it.
There are flex shaft extensions for 1/4" drive socket kits so you could buy an assortment of those and use a standard 1/4" drive twist handle with a 1/4" drive socket. Since not every hose clamp uses the same size driver, you would have the ability to make a flex driver with any size socket.
Return to Tools
