Recommend me a good torque wrench
Postby Paul Alexander » Thu 06.08.2015, 09:35
Hi Folks,
as the thread title says really. i'm not sure which to get, as i see so many with different ranges, so ideally can anyone recommend a good torque wrench with a decent range for working on the elan?
cheers.
Paul Alexander
Re: Recommend me a good torque wrench
Postby HJ2 » Thu 06.08.2015, 11:29
It's all a matter of budget to start with Paul.
When you set the budget for yourself, then you can find the best bang for the buck.
Without budget limitations: Go for Snap-on or similar A-brand :D
Postby dapinky » Thu 06.08.2015, 11:39
Hi Paul,
As a skinflint I'd say go for 'cheap and cheerful' :lol:
Okay, lets qualify that a bit.......
.... over the years I have collected a few of these things, and tend to keep one in the boot of each car, plus a couple in the garage.
My "best" one is a Snap-On one, and is a joy to use - easy to see what setting it's at, easy to wave around, and it gets sent back to the company every year to check the callibration - it has a lifetime guarantee and has Nm & Lb.f scales....... Oh, but it cost nearly £200 :shock: (they do a digital version now which costs £250 and is meant to be the dogs danglies).
Next down the list is a Draper Expert which cost about £30 - Nm, & Kg.f scales (with a conversion chart for those of us who still think in Ft.Lb).
Then there are the 'bargain basement' ones from Lidl which cost about a tenner each. (look identical to the Draper one, but not as 'smooth' to use).
Just to see where they were all at, I tested the cheaper ones against the Snap-On when it came back from callibration - at the lower end of the scale all were the same accuracy, at 65Nm the 2 cheaper ones were about 1Nm out (wheel nut setting), and at 120Nm about 2-3 Nm out.
This is close enough for most applications - and they were tested at anything between 3 - 10 years of age/use.
So, if it is for regular (or highly accurate) use, I'd say you can't beat a good one, but for occassional use then a cheap one will do the job just as well.
As for the range needed, (I still find the odd nut that mine wont do for, even with a selection!), I'd suggest 40-200Nm or thereabouts for a half-inch drive is a reasonable range.
My actual recomendation to you would probably be a Draper #30357 with a range from 30-210Nm (can be had for under £30 delivered from Amazon, Ebay or others)
Postby Paul Alexander » Thu 06.08.2015, 14:52
cheers guys. i got bamboozled by the sheer choice of wrenches.
dave, i've ordered the draper one as recommended, plus other tools. i've got a feeling i will have to remove my turbo after my holiday :(
(yay cheddar, here we come). :D
Paul Alexander
Postby simonbuk » Mon 26.05.2025, 23:18
I was just about to ask this exact same question !!
Anymore/other reccomendations for a suitable torque wench ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Saltire » Tue 27.05.2025, 08:30
dapinky wrote:My actual recommendation to you would probably be a Draper #30357 with a range from 30-210Nm (can be had for under £30 delivered from Amazon, Ebay or others)
Gone up recently, Dave. Amazon now want £42 :( Cheapest supplier is Toolstation at £38
Postby dapinky » Tue 27.05.2025, 10:07
In fairness, Jonathan, I did write it 10 years ago! - and the Snap-On units are now north of £500.
(But the gist of my original answer is still my current thoughts)
I have since added to my tool cabinet a 3/8" drive Draper torque wrench for those smaller gaps and lower tightening figures - but the range still goes up to wheel nut type things.
Postby simonbuk » Tue 27.05.2025, 10:50
Just ordered a Draper 1/2 and 3/8 torque wrench from Toolstation - £70
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Saltire » Tue 27.05.2025, 18:00
Well, Dave, if politicians can be pilloried for things they may or may not have said ten years ago, why shouldn’t forumisti? :lol:
Your recommendations are absolutely still valid though, and I always go for Draper if they have a product of the type I’m looking for. Their customer service is great too; I recently had a failure on a 10mm ratchet combination spanner, and they replaced it without question - even though it was the best part of ten years old.
Return to Tools
