by Blaster » Tue 01.09.2020, 20:39
While removing the oil hose I found this wire laying loose and no where to plug it into.
- Attachments
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
1995 Defender 300TDi 2012 Ducati Hypermotard
2018 AC Nitro 200 and Dudek Solo wing
Blaster
by dapinky » Tue 01.09.2020, 21:18
Hard to tell from the picture, but if it's a black/blue wire, in that sort of area, it is possibly the wire that should be on the high pressure switch on the bottom of the PAS pump.....
- LEC Administrator
by Blaster » Thu 03.09.2020, 18:49
Hose repaired and fitted with no leaks that I can see. Wire crimped with a better crimp to connect to the power steering pump.
Onto the next niggle.
Tony
Blaster
