From Alfa's to Lotus?
Postby Gennaro » Thu 08.11.2007, 15:57
Hi all,
I just joined, and I'm heavily considering buying my first Elan very soon.
But I've been an Alfa lover my whole life. I have a 1995 Alfa Romeo 164LS & a 1991 Alfa Romeo Spider Veloce. And I'm also currently restoring a 1974 GTV.
I know nothing about Elans... :?
I live in Manhattan, NY. And I have an amazing mechanic in Baldwin, Long Island.
But all he works on are Italian cars. Everything from Lamborghini, Ferrari to Alfa's....
Does any one know of a reliable mechanic in the Tri State area???
thanks,
Gennaro
Gennaro
Postby rip » Thu 08.11.2007, 17:36
Hi Gennaro, welcome to the forum.
I have no experience of Alfas so cannot compare them, but the Elan is a fun car to drive. I hope you find a nice one.
The Elan contains parts from many cars, but I am not aware of any Italian components, unless you fit Pirelli tires of course!
Under the hood, it looks like a typical FWD car, but without the battery or washer bottle and with the addition of the turbo, oil cooler & light pop-up mechanism. Space is understandably at a premium here too.
Most of the parts are of GM origin and I have found myself importing bits from the US on more than one occasion. You will find cross-references for most things on this site.
Postby Gennaro » Thu 08.11.2007, 18:59
Where can I find a cross-references list?
Gennaro
Postby clemo » Thu 08.11.2007, 21:59
hello and welcome to LEC.
i would guess that if you are an alfa man then you would be an elanman just fine..
i would say that the finer gremlins that occasionaly try your patience with you alfa may crop up on an elan from time to time.
not saying that either unreliable , but i guess both marques are that bit special..
so on that happy note ..
try one ..
you'l love it .
and once you hooked .. thats it... elan for life..
bye for now
clemo
scroll down and the part cross reference is in the technical section.
clemo
Postby rip » Thu 08.11.2007, 23:57
You will find it invaluable. I am sure I would be struggling to keep my Elan on the road without it. :D
Mechanic?
Postby Gennaro » Fri 09.11.2007, 19:06
Thank you so much for the quick replys...
But, no ones knows of a good mechanic in the tri state area???
Or should I just take it to an Izusu mechanic?
Gennaro
Re: Mechanic?
Postby tweetdriver63 » Fri 09.11.2007, 19:32
Gennaro wrote:Thank you so much for the quick replys...
I've only taken mine to a mechanic once. I needed a new crankshaft pulley (harmonic balancer, if you prefer), and the thermostat outlet pipe was cracked (my fault) and needed replacing, and I wanted to change the timing belt and all drive belts at the same time. I didn't want to fool with doing all that myself. Although I did handle getting all the needed parts myself.
The shop I used is a generic import shop that had worked on my Isuzu Impulse several times, and had done a good job at a very fair price. They had always been easy to talk to/influence (ie, they don't get all superior when you try to tell them a little about "how to," like many places do). I provided them a copy of my CD of the service manuals, etc, and even printed a few things out for them to save them some time.
Anyway, to make a short story long, they did quite a good job, and I have found several little things fixed that weren't even on the menu at the time (the hood release cable had come out of the handle under the dash-they fixed it, the vacuum sending unit for the boost gauge needed to be re-mounted with new mounting hardware-they fixed it).
Obviously, a mechanic familiar with the Elan would be best, but I think any competent and trustworthy mechanic can handle it. I would make sure they don't have any problem with you bringing them infomation from here about specific jobs, when it's available. If they act like they'll ignore it, go somewhere else. If they say, "great," recognizing that they're going to be working on a rare, quirky car, and will themselves be learning, then give them a shot.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Thanks,
Postby Gennaro » Fri 09.11.2007, 22:21
Thank you Chris, and all you guys....
This will definilty help me in buying an Elan.
But what about parts? Is there a place where you guy's all go for parts???
Like I use International Auto Parts for "all" my Alfa bits & Parts.
http://www.international-auto.com/
Any thing like that for Lotus Elans?
Gennaro
Postby Doug » Fri 09.11.2007, 23:17
you could get driveline parts from Isuzu if needed, but no Isuzu dealer will touch an Elan. Even a Lotus dealer probably has little or no experience with Elans, since most of the current dealers in the US sprung up to grab wads of money from rich middle-aged guys wanting Elises. Find a good general mechanic or import specialist -- the Elan is easier to work on than about any other car IMHO.
Re: Thanks,
Postby tweetdriver63 » Fri 09.11.2007, 23:27
Gennaro wrote:Thank you Chris, and all you guys....
The official supplier in the US is Dave Bean Engineering. you can find them through their website. They've been very helpful when I've called, and so far they've had all the parts I've needed from them, but they aren't cheap, as you can imagine. I usually call them early in the hunt to check what their price is, for comparison purposes.
The parts cross-reference section here is a gold mine. That's where I start. Then, if the part is cross-referenced to another GM vehicle, I go for the normal parts sources (NAPA, Autozone, etc), if not, I ask the folks here first. Some parts have been pretty easy to find on ebay or ebay.uk, and there are a few specialist salvage yards around the country, too. As a last resort I call Dave Bean.
I hope all that helps. Generally, I've found (so far) that parts aren't all that hard to find, since most of them came from other GM cars.
'91 Elan SE
tweetdriver63
