New/Old Pocket Rocket has arrived
Postby s1ghthound01 » Sun 12.10.2014, 09:11
Well, the little Blue thing has arrived and of the transporter. Yep I did everything you shouldnt do when buying a Lotus, bought blind, untested and over the phone and it's not the first time. :bonk: This little Pacific Blue SE will be my wifes runabout so here goes on future work.
She is for sure cosmetically challenged but with a bespoke interior which is rather good. So far I have found the boot lock has been disconnected (electronic ) and a piece of pull wire fitted so that it can be opened, drivers door lock does not work. passengers door lock, lock's but wont open and the petrol flap would not open, now fixed. Her saving grace is that mechanically she is in ace condition having had a few thousand just spent on her as the previous owner had bought her as a restoration prjct which stalled due to a divorce. So now I need to find all the fasteners that hold the dash binnacle together as it is presently ver loosly held in place, fix the boot lock (change to a standard lock) as the switch on the dash has been butchered and it looks like she has had a few elecectrical issues with the alarm having been removed and central colcking only clicks on one door. So here goes the saving of another little Lotus which I am sure was going to end up in the parts bin as it had languished in the po's garage for the last two years, I suppose we are lucky in that he spent a few thousand on her to get her back up and running with invoices for loads of new parts includeing bushes, radiator, cooling pipes, fans, thermal switch, brakes front and back, new tyres, belts and a full service complete with a fresh MOT and loads more.
But I must add, she runs fantastically well with her being chipped, Sparco dump valve and induction kit.
So as with any good forum I will be looking for loads of help and advice
Thanks in advance guys, I am going to need your help, and the fact that I work away from home for a month at a time means this will be a long drawn affair. :roll:
Wendy & John
s1ghthound01
Re: New/Old Pocket Rocket has arrived
Postby Steve A » Sun 12.10.2014, 14:27
:poke: get some photo's posted so we can see what you've bought
Postby Ian T » Sun 12.10.2014, 15:45
Sounds to me like you bought a call that was pretty well described and I hope there weren't too many surprises or disappointments when it arrived. Buying a project can be a good way to get the car you really want, as you get to put your own mark or standards on it rather than ending up with something that is "nearly good enough" and is hence not worth re-doing.
Welcome to the forum, and I look forward to seeing you make progress with it - do you have some photos for us?
Ian.
Ian T
Postby dapinky » Sun 12.10.2014, 17:10
There is an undoubted advantage to doing ANY job if you have a 'completed' item to refer to - I hate to think of the number of times I've been glad of a second Elan when doing jobs on the other one, only to have to think really hard about which bits go over/under/round other bits upon reassembly.
No matter how simple everything looks when taking it apart, it's never so easy when putting it together - and I'm a lazy bugger who often fails to photograph things as I go along, relying on a (fading) memory :?
Oh, and the 'source' of instantly availlable 'spare parts' is also invaluable - even if only to test the functionality of certain parts.
Postby Fourdoorcat » Tue 14.10.2014, 19:55
Welcome to the forum! I'm sure you will find it full of helpful and knowledgeable folks.
Please add your location to your profile so we understand what part of the world you inhabit.
Ken
"Never ascribe to malice that which can be perfectly explained by stupidity"
Fourdoorcat
Postby s1ghthound01 » Thu 23.10.2014, 03:41
Thanks guy's, to date I have completed some temp repairs on the splits in the roof cloth,usual problem of having been poorly stowed away so I used a couple of old seat belts to effect a temp repair. Biggest issue at the moment is all the fasteners for holding the speado binnacle in place is missing so I have it held firm with a couple of tie wraps. Contacted SW Lotus but heard nothing back from them, I am also looking for a mechanical boot lock assembly rather than try and repair the electronic unit that has been fitted as it looks like it has been butchered. The interior is pretty good having been redone by a company called KSH in the Newcastle area with bespoke seats, Magnolia leather with Blue inserts on the base and back to match the color of the car and the Lotus logo embroidered into the headrest area, must say looks rather smart and cleaned up a treat, now just need to get some color back into them. Loads of minor issues like the usual lacquer peeling off the boot lid, a couple of minor cracks on the front spoiler, door window wiper seals need replacing so will be looking for pats for those as well. I will try and get some pics listed but as I am currently at work in Kazakhstan it's not the easiest thing to do as we simply cant trust computers over here.
No doubt like the TLF which I am a member of I will be looking for loads of advice so I will say thanks in advance to any received.
John.
P.S. A bonus, her indoors loves it and it means she wont get to wreck my S4. LOL. :burnout:
Wendy & John
s1ghthound01
Postby s1ghthound01 » Thu 23.10.2014, 13:15
After several requests I have managed to get SWHBO to send me some photographs for posting, so here goes and hope it works.
https://mail.aol.com/38815-111/aol-6/en ... l&partId=4
https://mail.aol.com/38815-111/aol-6/en ... l&partId=3
The last pic is not that great but all I have at the moment.
s1ghthound01
Postby rip » Thu 23.10.2014, 14:31
I need an AOL Login for those, so I can't see them. :?
Postby cliff » Thu 23.10.2014, 21:21
Hi and welcome.
I bought mine unseen - never even driven an Elan before so welcome to the club.
I have an AOL login but I can't see your pics either, this might help
viewtopic.php?f=14&t=8957
Having worked in a few less than salubrious places myself, I found the best way to get round local internet restrictions was to use a remote login to a home PC in Europe. The remote login lets you control the PC as if you were sitting in front of it.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby s1ghthound01 » Fri 24.10.2014, 13:20
Hopefully you can see the photos now :D Wendy
s1ghthound01
Postby John_W » Fri 24.10.2014, 21:24
John & Wendy,
Glad you found LEC OK. I'm happy that you've got an Élan. You know where to come and see a good one!
If you need bits, I'd recommend Steve at SJ Sportscars.
It's nice to see you here. Welcome.
Good luck,
:cheers:
Postby Rambo » Sun 26.10.2014, 13:30
John_W wrote:You know where to come and see a good one!
I presume you mean 30 miles south of Embra' John ? ;-)
Postby tb10 » Sun 26.10.2014, 17:35
s1ghthound01 wrote:Hopefully you can see the photos now :D Wendy
Welcome!
I'm sure that you'll find this forum very helpful for all of your Elan needs :cheers: I hope you enjoy your car.
Regarding your car, and my first observation, I must say that those are some very interesting A Pillar seals. :poke: What are they made of?
regards
tb10
Postby s1ghthound01 » Thu 30.10.2014, 15:56
A frame seals are looking good, not. they have been bolstered out with some foam, one of her many cosmetic issues to be seen to but they do keep the rain out.
Wendy & John
s1ghthound01
