New Member
New Member
Postby PAC » Thu 23.03.2023, 13:45
Hi all
I purchased my Elan in August 2021 but have only just joined. I have an M100 series 2 in Silk Red Metallic Edition 292. It is great condition having only done 45,000 miles and had just one previous owner from new. Not up to doing major stuff myself but fortunately it has been kept up to scratch including new cam belt recently. I had to have a new radiator this year plus some hoses that had perished. I have a problem with the alarm which is a retro-fit Clifford Concept 50x which seems to constantly drain the battery. I will have a look through the forum to see if the issue has cropped up before. Super car to drive and great to be part of the M100 community!
Series 2 Edition 292 Silk Red Metallic
PAC
Re: New Member
Postby White Elan Man » Thu 23.03.2023, 18:33
Welcome from another newbie, that’s a nice car you have there!
White Elan Man
Re: New Member
Postby exeterjeep » Fri 24.03.2023, 16:58
Alarm issues on S2's are a common feature, often all the alarm stuff gets removed, so you have to lock/unlock with the key. There is someone (well at least 1) who have managed to get an aftermarket remote fob to do the door locking/unlocking.
exeterjeep
Re: New Member
Postby TrevorB » Fri 24.03.2023, 17:41
Welcome to the forum and the Silk Red brigade.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Re: New Member
Postby Saltire » Fri 24.03.2023, 17:58
exeterjeep wrote:Alarm issues on S2's are a common feature, often all the alarm stuff gets removed, so you have to lock/unlock with the key. There is someone (well at least 1) who have managed to get an aftermarket remote fob to do the door locking/unlocking.
And that would be me! I’ve stripped out my old (and temperamental) OEM Gemini Aquila alarm, and replaced it with a Toad Ai606T2 with a central locking interface and remote window closure
Re: New Member
Postby PAC » Fri 24.03.2023, 18:28
Thanks for your response. Re: the alarm, looking on the Forum, I either fit a switch to isolate the supply when the car is in the garage, or replace the alarm with something more up to date. If I could find where they have hidden the Concept 50x control unit it would help!
PAC
Re: New Member
Postby MPx » Fri 24.03.2023, 18:37
Often next to the battery behind the seats...have you checked in there? ...and welcome btw.
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Re: New Member
Postby Saltire » Fri 24.03.2023, 21:36
MPx wrote:Often next to the battery behind the seats...have you checked in there? ...and welcome btw.
That’s not where the OEM S2 alarm was located though, Mike. If PAC would like to email me, I can supply more details; I tend not to put alarm info on the open forum :D
