Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
Tuga2112 wrote:just to re-iterate.
is your plan to start driving the car as soon as its possible/safe ? or to do a full out restoration before you experience its drive ?
HJ2 wrote:As long as you are painting the engine bay, then engine-out sounds reasonable.
However for alternator + belts, pulleys, thermostat, waterpump...
it sounds a bit like overkill to me! There are better ways to spend your pennies.
Relevance wrote:the technicians want to remove the engine to do the alternator
Relevance wrote:I have new belts, pulleys, water pump, thermostat, gaskets, etc ready to be installed.
Tuga2112 wrote:i understand its your car and your decision. but i fear removing the engine is likely to escalate to a lot more work around bits that will be damaged or are "dry" and will crack. and theres always the risk of fitting something incorrectly etc.
Tuga2112 wrote:I Have 77 videos with "m100" on the title, the majority are from the work done on the yellow car and theres a few that are not public.
you proobably will find that the majority of what you want to do is already documented there. and obviously this forum is where i have learned to do what is there (with some exceptions where i do things my own way)
dapinky wrote:Not sure if it is mentioned elsewhere on Joaos links, or in this thread somewhere, but although the Impulse alternator is slightly larger in the casing than the Elan alternator, with the prongeron out it will go in easily. Especially if they are already whipping the engine mounting off to get to the timing belt and waterpump......
dapinky wrote:Jake,
Okay, so the engine is coming out (I wouldn't, but not my job!).... some things to consider:-
Getting the engine out on it's own isn't possible as there is no room to separate it from the gearbox shaft because of it's proximity to the right-side chassis - so it has to come out with the gearbox.
I expect that the driveshafts will be out anyway to do the suspension, but it is worthwhile fitting new output shaft seals to the tranny when re-installing it to the shafts. (They're only a couple of bucks each at Rock auto (and elsewhere, I expect) - do not just get a pair of Impulse ones as they use different sizes left/right - you need two LEFT ones - https://www.rockauto.com/en/moreinfo.ph ... 92&jsn=467
There is little room (front/rear) to get the whole lot out without removal of either the inlet plenum or the exhaust manifold/turbo.... it is possible, but not easy.
The three choices are either to remove the exhaust manifold/turbo first, remove the clamshell, or - probably easiest in your case with the other stuff being done - drop it out from under the car.
I can't see it being a 2-3 hour job though!
Well it's nice, but it's hard to beat 20+ years of experience on a car though. They might be experts on Ferrari, but unfortunately it's a Lotus they might not know at all?Relevance wrote:these guys are top notch mechanics
Giniw wrote:Well it's nice, but it's hard to beat 20+ years of experience on a car though.Relevance wrote:these guys are top notch mechanics
dapinky wrote:Jake,
I'm not suggesting that they can't do the job, and if they think that it is overall a better idea to whip the whole thing out, then it may well be.... and out the bottom is certainly the easiest way as the things that make it difficult to do (driveshafts and prongeron) will be coming off anyway.
I was purely saying that I wouldn't do it that way (but I'm working on my own without a decent 4-post lift!)..... and pointing out the difficulties with taking it out the top with everything still attached.
Relevance wrote:Giniw wrote:Well it's nice, but it's hard to beat 20+ years of experience on a car though.Relevance wrote:these guys are top notch mechanics
Assuming you're talking about Dave, it would be impossible to beat the knowledge and experience he has with this car and I am in no way trying to undermine his expertise. My point was more so that if I were doing the work with my own two hands, I would be treating all of the advice I've received like gospel; since I am not, I was trying to just state the car is in the hands of competent mechanics. Given the rarity of Elans in the US I agree with you and do doubt they've ever worked on one, but at the shop they maintain, among other brands, 2 Esprit (one 4cyl, one V8TT) an Exige, and an Evora GT and have familiarity with the headaches that can come with those. Due to the extremely meticulous work of this community, which I am extremely grateful for, I was able to supply them with all of the factory literature which can be invaluable for a project like this.
Giniw wrote: (in general, maybe these ones are the best and will read the manual)
