Rosie's return to glory
Re: Rosie's return to glory
Postby TorqueHorse » Thu 02.10.2025, 13:50
Jamie N wrote:
Gov ultimately to blame.....
Would now be a good time to tell you about Nord VPN and the benefits of data security? Just use promo code.... :roll:
Well that stinks. I guess I'll try and upload photos directly here going forward. In the meantime, I have all my photos here if you want to just browse without any context (or editing) https://photos.app.goo.gl/1oc6GPeTC3pWPiJFA
'91 FED M100 -rolling resto
Postby Jamie N » Thu 02.10.2025, 17:59
Well versed with VPN Matt but this is much more than losing pictures on a car forum for us in the UK, not going turn it into a political debate on here as it's not the place, but the scenario with Imgur is just the very
thin edge of the wedge.
Monaco S2 #406
Jamie N
Seal God
Postby TorqueHorse » Fri 03.10.2025, 03:06
Ok, dug some more in the fuel system today. Could not get a picture down inside the intake with the cheap amazon borescope, so tried just seeing how much fuel was coming out at the rail. Pulled the injectors and made a little tray from an old motor oil container.
Does this seem like enough to create 40psi inside that rail?
Pulled the hose off right at the tank and ran the pump again and captured about the same amount.
Detached the fuel hose connection behind the intake and then used an airline to blow out both the fuel rail (with injectors still removed) and then the hose from the tank up to the intake connection.
Then I pulled the fuel pump out and found this split in the hose at the pump.
Took trips to both autoparts places near my house to find some 5/16" fuel hose, and by the time I got back, the light was gone, so will have to wait until tomorrow to see if this is finally the problem.
Postby FunElan » Fri 03.10.2025, 05:57
That is great detective work!
FunElan
Postby TorqueHorse » Fri 03.10.2025, 17:39
New hose at the fuel pump seemed to do it...finally
Sounds like my lifters lost some oil after a year sitting around. Hopefully they will pump up on their own.
Now on to putting everything else back on the car :lol:
Postby Tuga2112 » Mon 06.10.2025, 15:49
i havent been looking at the forum lately but well done on the fuel pipe split.
years ago i had a somewhat similar situation where after re-installing the fuel tank i didnt tighten the fuel pipe jubilee clip enough and it worked itself loose. there was some fuel going in, enought to start the car eventually but not to keep it idel unless i removed the MAP sensor introducing a vacum leak
your situation is very similar same. but with rather drastically different simptoms
