Coolant: I found the leak and yes, it was due to an old brittle hose. Once I saw the temp gauge get that high, I immediately pulled over and called for a tow. There was only white steam coming from the culprit. Was an easy fix and now no liquid leaks!
Maybe I will give the yellow cap another shot. I'm using the luxury of having a daily driver to give these cars a face lift through the process. Very excited to share the before and after with the forum down the road.
Vacuum: I didn't want to try the water trick on the air lines because the idle is already dodgy without external manipulation. The o-ring type seal around the Air Filter outlet adapter just after the Air Filter Housing was disintegrating so I put a replacement seal on for the scan. I would like to find a better one for the long-term.
Furthermore, I have seen my daily driver read 120F (48.89C) on the highway out here in the middle of summer so I will put the pesky hose on my check list. Hopefully cross it off before the floor becomes lava!
Tacho: The check engine light has never come on when its not supposed to, and I checked the bulbs lol. In my scans I get readings of over 3,000rpm and by the sound of the engine when I'm driving, it doesn't seem to cap out. I've never hit the limiter, although I have driven the engine over 3,000 rpm so I believe it might be a mechanical issue with the needle itself. There is a little metal piece and the physical needle seems to get caught on it. (Any tips on uploading .jpg to these posts?)
Tuga, your videos have helped me tremendously on many projects and when I first took out the dash to check the continuity of the circuits everything seemed to check out. That was a couple months ago and I want to do another check with the information I have now. The main thing stopping me from opening up the cluster is how brittle it is. While I was working with it, it was easy for the tabs to disintegrate and the clear plastic front is crudely glued to the back housing. I'm not keen on the local laws when working that close to the odometer, especially when my registration depends on it, so I want to make sure I know what I'm doing.
Attached is a 20min warm up scan, thank you all for your input!
