TommyK wrote:If you don't mind me asking, how much did your downpipe and exhaust set you back?
Houdini wrote:PASSED SMOG![]()
That involves the following:
1) Connect Stock ECU
2) Put back the stock injectors (RC sticker gives it away)
3) Put back 2 bar MAP sensor
4) Remove blow off valve and piping and replace with stock
5) Put back the stock air filter can with something close to stock ducting
6) Remove MBC if it's still on car
Doc Fizzix wrote:Houdini wrote:PASSED SMOG![]()
Ok, give me a brake!![]()
How in the world is someone who inspects the car going to know that you did not just replace the injectors with the "stock" injectors of 330 cc? Maybe all that is avalible for the Elan is RC injectors.![]()
Also, how would they know about the 3 bar vs. the 2 bar MAP? What kind of inspections are going on in CA? This sounds a little crazy
Houdini wrote:3) Run a wire from the oil pressure warning light to the engine check light. (When they test your car they check to see that the light is on before starting the car or it fails.)
