novacaine wrote:I think the fluttering your hearing is excess boost returning back through the turbo when you release your foot off the accelerator to change gear. Its nothing to worry about, it just means your turbo will take a little longer to re-spool as the fan is blowing in the opposite direction. Dump valves are fitted to prevent the return of boost back through the turbo. If it gets on your nerves get yourself a recirculating dump valve, you wont here the typical pfffftttffftt that a standard dump valve makes as the air is recirculated back into the filter box and it will prevent the back spin of your turbo, meaning less turbo lag.
rip wrote:Am I the only SE owner who has no problem with the storage box? When I learned to drive, I was taught to change gear using the palm of my hand on the side of the gearknob. Like most new drivers, I did not get on with this & grabbed the gearknob from above. Later I re-taught myself what I was taught by my instructor. This gives me more feel when changing gear, allows me to change gear more gently, makes gear changes more comfortable & enjoyable (yes, really) & I find it lifts my elbow a little higher.
