by Elanlover » Mon 15.08.2022, 19:00
Those screws can be loosened to adjust the position of the seal up or down. I'd loosen them again and see if the seals will slide down to meet the window (unless that's what you tried).
by plannerphil » Mon 15.08.2022, 19:04
Elanlover wrote:Those screws can be loosened to adjust the position of the seal up or down. I'd loosen them again and see if the seals will slide down to meet the window (unless that's what you tried).
I slid them down as far as they'd go but I still get the gap in the pictures. It's better than before but still quite a gap.
plannerphil
by Elanlover » Mon 15.08.2022, 19:22
Another thought - inside the door cavity there are window stops. Perhaps they need adjustment? Or, the window motor mechanism itself?
