Rosie's return to glory
Re: Rosie's return to glory
Postby TorqueHorse » Fri 18.03.2022, 23:30
FunElan wrote:now THIS will be fun. Looking forward to seeing your (quick) progress!!
Not sure when you ordered the Samcos, but they seem to take several months to make. I ordered mine in Jan and they should get to LA by April apparently.
Thanks! Well I haven't lived up to my deadlines for over two years now, so why start? :P But honestly I've done most of the jobs left already once before, so I think I'm better prepared to actually execute this time round.
I ordered the Samco's near the end of Feb, so I'm hoping by the end of April here. Maybe since they have to fire up the molds for you, they'll get to mine faster too? One can hope :)
'91 FED M100 -rolling resto
Postby TorqueHorse » Sun 20.03.2022, 23:50
knock two down, add one more
More work than I planned this weekend, but ended up pretty much on target.
Got the fuel pump replaced. I broke the plastic piece that holds the bottom, but I think I've managed to wedge it all together so it won't be a problem. But easy enough to find out when it's running again I guess. :roll:
Also managed to drain the tank, clean it, and purge the fuel lines with compressed air. Oh, and I saw some evidence of cracking/crazing/staining in one of my repair area on the tank. No leaks yet, but I will be there is another tank-off job in the future (but not now).
Got all the brake hoses off, and ran an air line on all the brake lines - what a mess brake fluid everywhere. I think I cleaned it all up before it did real damage to the chassis paint. A lot of the friction shims were super hard to get off too, but ended up alls well. I got distracted thinking about refurbing the steering rack too, while the engine is out, but I was able to curb the creep and just finish what was on the list. Probably because that is when I broke one of the brake hard lines, trying to get it bent back into shape.
dems da brakes
Now to find some replacement material and see if I can shape that without breaking it. :roll:
On to what was really on my list for the weekend...Sanded, and put some rust remover on the brake servo.
Then a couple of zinc primer coats later and a rust-olem top coat, I have it not pretty, but ready to go.
not pretty, but should hold a seal
Now I'm just waiting for that BMC and I can put that and my new lines and rebuilt BPV's back on the car. And then bleed the bejesus out of it all :) .
Postby TorqueHorse » Sun 27.03.2022, 02:47
Double no bubble
Got the old hoses and clamps off and my replacement hose trimmed and back on. I pressure tested everything again, and was excited to see no bubbles, and no water inside either.
I reused the existing insulation for now; I've got replacement foam, but I think I'll wait until I refresh the suspension and clean up the other stuff down here. So now I've got it all mounted back and ready to hook up to the engine.
I'm going to be on hiatus for a bit doing other stuff, but hoping to get the valves back in in April and clean/prep the rest of the bottom end parts, so that I can assemble and install come May.
oh, and I found a replacement brake line on order and I got a pipe bender and flare kit. The pipe is a bit longer than I think what is needed and I might be able to just shape the pipe to fit, but otherwise, I'll try cutting and double flaring it.
Postby FunElan » Mon 16.05.2022, 20:45
I think we're overdue for an update here :D
FunElan
Postby TorqueHorse » Tue 17.05.2022, 05:07
Uhh, yeah. Update is that I'm behind on my updates ;)
Short story is that Jag neighbor begged for another month, and I accepted since I got saddled with an unexpected work trip and an unexpected visit from in-laws, throwing me off too.
Good news is that I got the rebuilt BMC back and it looks sweet. Bad news is I learned the hard way that there are two flare types for brakes, and we use the bubble type. So after my second order I almost have the replacement pipe bent to shape. Need a clear weekend to install the brake lines and bleed.
Rebuilding the engine now. Bottom end is all back together and I put the head on last week. Timing belt is back on and so is the alternator. I also got my Samco's delivered so I'll be putting them on too. And my new "uprated" fuel injectors. Should be able to put the fly/clutch/tranny on by this weekend.
If so then I really won't be that far off my goal. And I better hurry because I've got more work trips sneaking up, so the extra time is kind of wasted on me. Photos this weekend, fingers crossed.
Postby HJ2 » Tue 17.05.2022, 07:25
Wow…
Postby TorqueHorse » Tue 24.05.2022, 15:21
Yeah, didn't get that far. Only got the intake side of the engine back on.
I did get my new shift cables installed though (thanks John)!
I seem to have a lot of play in that main ball-joint of the assembly too though, like George. It's not to the point where I need to replace it just yet, but it's nice to know what needs replacing if I get that far.
The main mystery of the weekend were these "blown" nuts holding the precat onto the turbo.
Two of these shattered like this (out of the 4 holding it on) and I had JUST replaced these when I rebuilt the turbo last year. My thought is that maybe the anti-seize I used got super heated and tried to expand quickly with nowhere to go? I might have also globbed it on thick thinking "these were really hard to get off the first time. Let me make sure these are really coated so if I have to take it apart again, it will be easy." Well it was a bit too easy, so I won't be doing that again.
And maybe, maybe if those had blown, the seal was loose, and the O2 sensor is right there, then maybe air was sneaking in and tricking the sensor and that is why it kept doing the weird surging when it was trying to idle? So deep down the rabbit hole of wild guesses. Need to get it back together and running soon! :)
Postby dapinky » Tue 24.05.2022, 15:49
I may be able to help you with the problem with the turbo nuts (or I may be referring to completely wrong parts!)....
.... AFAIK the nuts are 'K-Nuts' which look like normal nuts, but are "miss-shaped" during manufacture, and are designed to do up, but not vibrate loose (think:- ratchet teeth). They should be fitted without any form of lubricant, and when you need to remove them, either the stud will come out at the same time, or they need a fair amount of force - suffice to say, they are single-use items.
Postby 378S2 » Wed 25.05.2022, 13:51
Hold up. Hold up.
You don’t get to go from putting your cylinder head on the barbie to a fully assembled engine without pictures of the bits in the middle. Did you do a Haggarty style flow-motion video that you’re holding back?
How do you rate my chances of getting the intake plenum off with the engine in the car so I can change my oil sensor?
Congratulations on all the progress Matt. You’re nearly there now.
378S2
Postby 378S2 » Wed 28.09.2022, 12:33
How is our friend Rosie doing Matt?
378S2
Postby TorqueHorse » Thu 29.09.2022, 04:54
For shame! Last weekend I officially lost the neighborly bet, as he got his XJS running and made it to the All British Car Show nearby...and took home 3rd place in his category. Now he's got a fancy plaque and I have a hunk of junk still up on stands.
I was in the lead in August having dropped the engine back in and it was running better than ever (I did have to bypass the IAC, but that's another story). New Brake hoses and rebuilt MC and BPVs in place; no leaks. New Samcos in and no leaks. New fuel pump and injectors, at pressure and no leaks. The front suspension was in, with the right clearance and no more rubbing on the cv boot. Short shift kit was installed with the new cables too. New coils, leads and plugs. New oil cooler hoses installed; no leaks. I'd even gotten brand new tires mounted on the wheels, ready to be put on and finally go on its (re)maiden run...
And then, clunk.
First it was just one wheel (really disk at this point since it's up on stands waiting for the wheels). Engine gets up to idle and I put the gear lever in what should be neutral and let out the clutch and I hear something (can't remember exact details). Thinking it's fine I put it through some gears, which seem to engage ok??, (I think I was more focused on rpms because of the IAC problem) and then back into neutral. From outside the car one wheel is spinning a bit and the other is dead stopped.
Long story short after a few more test fires of the engine.trying to chase down the IAC problem, now neither wheel spins at neutral, and when I put it in gear there is a clunk (forward gear or reverse). With the engine off if I go to the wheels and try to spin them manually, the cars left side, I can rotate it about 5-10 degrees with immovable "clunks" at either end. The otherside (with the jackshaft) rotates a bit more with maybe 10-15 degrees of play, but that same , solid, immovable "clunk" at the ends.
After some internet searches making me feel stupid for leaving the transmission drained and sitting unwrapped in my garage, collecting condensation, and then all the other possible scenarios of what it could be leading to the procedure of taking off the transmission to check it out, I conceded defeat and promptly started the engine removal process again.
Now work, weather, family, and friends have conspired against me since then and I haven't had time to do the final parts of the process to actually lift it out of the car. Should have a good block of time open up in a couple weeks. Then it's off to the transmission shop for this problem diagnosis and fix (hopefully) as I really don't want to invest another year in learning about how to tear down and rebuild another critical piece just right now :)
So the upshot is I'll have to wear the big cat of shame while I toil away on this next part, but I'm betting third time's the charm on this.
Postby TorqueHorse » Thu 29.09.2022, 05:04
Thanks for checking in though, George. I'd been meaning to post an update, but...yeah. :)
Postby FunElan » Thu 29.09.2022, 06:52
What a roller coaster!! Was waiting for a check in too. Ugh...hope this is solved soon and not too intensive of a fix
FunElan
Postby TorqueHorse » Thu 13.10.2022, 21:10
Clunk, Clunk you big lunk
After a couple months of on again/off again time to work on the car, I'm down to step 18 out of 20 for the removal process. I just freed up the driveshaft off the jackshaft and...now the jackshaft spins freely :shock: . I went back to the brake disk and it still wouldn't turn :evil: How is that possible, it's not attached to anything?!? The brakes aren't binding, but...oh I have those wheel studs screwed in all the way down to the disk. And when I back them out a bit, viola, now it spins. Same thing on the other side. The studs were just catching on the hub carrier. That's why it would spin for a few degrees, but not more. :oops: :lol:
Screwing these in too far without the wheel attached really screwed me.
Sooooo, transmission crisis averted; back to putting humpty dumpty together again, again. :bonk:
Postby 378S2 » Fri 14.10.2022, 02:19
Ah man that is both wonderful news and a painfully learnt lesson! Quickly reverse those 18 steps and pretend it didn't happen...
378S2
Postby chrism » Fri 14.10.2022, 11:57
+1 - and grateful that you shared it! Any of us could've done the same...
chrism
Postby TorqueHorse » Sat 22.10.2022, 20:34
I don't want to jinx anything, but here is a sneak peak teaser for what's up...
Actual update to follow depending on how it goes this weekend. :D
With F1 in town, maybe the motor gods are smiling on me?
Postby FunElan » Tue 25.10.2022, 05:01
ok, after that photo we NEED an update!
FunElan
Postby HJ2 » Tue 25.10.2022, 13:04
Drrrrrrums please!
Postby 378S2 » Tue 25.10.2022, 14:20
Has the lightly barbecued engine fired back in to life?
378S2
