MattDon wrote:so the elise steering wheel has arrived and holding it upto my brg (which has the steering wheel removed) im a little confused, ive looked at 2 threads discussing the fitment but im still not 100% my biggest puzzle is over the collapsable hub, the standard fair has four holes to attatch to the column, fair enough, the elise does too but the confussion comes when i compare the way the wheels are attatched to the hub, the elans has 6 bolts but the elise doesnt seem to have any, so im assuming the bolts that hold the hub onto the column also hold the wheel to the hub which is hidden inside the steering wheel!??? Id search for more posts but for some reason i just keep getting no results found on the advanced search.
Matt,
I have done a write-up somewhere (on the wiki as well) on the steering wheel swap....
....basically, the elan hub needs to be unbolted from the elan steering wheel and then bolted to the elise wheel - the colapsable spacer doesnt get used with the elise wheel, as the hub just bolts up to the wheel with 4 M6 bolts/nuts, or alternatively, you can use the colapsable spacer, but fitted on the other side of the steering wheel (i.e. just using it as if it were a set of 4 captive nuts on the threaded bits, but not being collapsable - does that make sence????) Personally, i don't use it, and just hold the hub to the wheel with 25mm long M6 bolts/nuts - however, should you need to remove the elise wheel at any stage in the future, the colapsable spacer is used as a surface to operate the puller on to get the hub off the spline, so if you don't use it, you will need to adapt something else to do the job!) - it should all become apparrent when you lookm at the bits in front of you...
