by tweetdriver63 » Tue 29.07.2008, 05:48
Since my BOV and escutcheons didn't show up yet, I decided, instead, to try installing one of my new A-post seals this past weekend.
The job isn't all that hard. I chose to re-use the carriers, and not to remove them at all. That way, I wouldn't have to deal with re-installing them and sealing all that up. If it ain't broke, don't fix it, right?
Anyway, the only semi-difficult part of the whole job was getting the carrier cleaned out. A flat screwdriver can be used to scrape all the old sikaflex off the flat part, but in the channels on the sides is a little tricky. I used a paint-can opener tool, like in the picture, and with its small, curved tip, it worked beautifully. (Note to the Wiki gods)
Well, along with installing the new driver's side seal, I thought it would be a good time to do a little patching on the intermediate seals. They weren't real bad, but there were places where the skin surface was getting a little rough, so I figured I could put a little sikaflex on them, and smooth it out with a latex-gloved finger. I just wanted to get a good smooth, thin coat over the rough areas.
The problem is that I over-looked a spot on the forward intermediate seal on the driver's side, and didn't smooth it out, so I discovered, after it was cured, that I have a blob of it, right in the groove where the windows fits, and it's causing a gap on both sides of it. I need some advice on how to remove that mound of sikaflex without damaging the seal underneath it.
Please. Any help is appreciated.
- Attachments
- the tool
- DSC03144.JPG (142.45 KiB) Viewed 8203 times
- the gap
- DSC03141.JPG (146.79 KiB) Viewed 8204 times
- the blob
- DSC03143.JPG (143.89 KiB) Viewed 8202 times
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
