thanks for the replies... foo its a great colour but one i find hard to match to, the hint of blue in it is what makes it tricky, for example black goes with red or yellow/gold orange etc and vice versa, green and yellow go well, grey and deep red go well, blue and white/cream, etc etc. As im looking to update the interiour too i need something that goes with something else, but dont worry i wont be respraying the car i have a plan!!!
paul.p im glad you find it entertaining, ive got to say i do have a soft spot for your car, it bring back alot of memories with the JPS colours.
Abit of a quiet period and then madness....
I had a few scares, the peco was causing boost creep the tappets had started to get noisey and id also had a day or two where loki was spluttering under accelerating, thankfully the spluttering sorted itself out, the wastegate had to be ported and i decided to have the oil changed in the hope it would sort the tappets, and thank goodness it did. So after buying the short shift, wheels, tyres, hispec brakes, ss hoses, dorman calipers and modified handbrake levers (which i still havnt got sorted, they stick) and a ton of various silicone hoses, pce and gaskets, i dropped the car in at the garage.... it gets a little hazy from here but after a few days i get a call saying the wheels wont clear the calipers and the car is blocking up their lift, so i rushed off to halfrauds and bought a spacer to tide them over and had a spacer to them within 2 hours, i later find out they didnt even use it, but i then set about trying to find either wheels that would fit properly or a decent spacer, in the end i opted for a hudcentric spacer of 10mm which was used, i also ordered some 34mm bolts for the wheels but it turns out they wernt long enough either, so i get a set of 42mm bolts ordered and they did the trick. so on went the brakes, hoses, etc etc, the day i was due to pick her up i went down as it was a quiet day for me, and paid £1000 an agreed price and tried to help out, we were there until 11pm trying to get the brakes to repressurise after a complete drain and refill, i was beginning to sweat as the current financial climate is hitting me pretty hard and i was on a VERY strict budget, which was dwindeling by the week, after another day working on the brakes they called me and told me that its suspected the master cylinder had died, so i gave them a cross referenced part number from here and they ordered it and fitted it within a couple of days, unfortunately that extra work and part had taken me well over my budget and i had to get a load to pay for it all
so i got onto ebay and made some tough choices about what i did and didnt need.
also at some point among all this i found a rather cheap BRG elan which was accident damaged but had ALOT of the essential work done, so i went cap in had to family and they agreed to loan me the money to buy this car, its essentialy a safty net incase anything goes wrong with mine. i know some people might but upset with me for using a car for parts but as it was recorded and my first priority was my car i took the plunge, the hope is that while stripping the car down i will learn enough to work on my own and also save some cash.
so back to loki, ive been running loki now for a few weeks, there are a few issues, ie its knocking and it does feel like the power is a little down, the handbrake lever is sticking, but i have replaced the seats with some much tidier leather ones, ive bought some speakers and amps to sort the music out, nothing to anti social just enough to hear over the windblast, the garrett kit has be paid for and the bov kit will be shortly, the adaptor plate has arrived and i all that will be sorted when i can afford the turbo. pretty high on my list is the interiour but im currently in turmoil as i was going to go with a subtle dark red interiour but if i do get around to changing the colour to candy burnt orange then id need to redo it all so its a bit tricky at the moment. im also looking forward to a smaller steering wheel, metal monkey dials, brushed stalks (fitted them today) and gearknob, and fitting daves shortshift and AB cables. As you can proberly tell its all a bit up in the air at the moment, i'll do what i can when i can afford to, and have to prioritise as i go.
