Elan Autorcross Project-Help Desired
Postby davisfoo9 » Mon 30.04.2012, 02:56
I have had an Elan for about 2 years and have been using it as my daily driver. I decided it is time to turn her into an autocross machine that is still driveable to and from the track. After reading a bit on the forums here, I have made a list of what I am planning on doing. As of right now, the upgrades I have planned are as follows:
1) AP Racing Front Brake Rotors/4 Piston Calipers from BG Developments
2) Protech fully adjustable suspension from SJ Sportscars
3) RC Engineering 550cc injectors and GM 3 Bar MAP sensor
4) Quaife LSD
5) Wiseco Forged Pistons
6) Ported throttle body and evergreen turbo upgrade from Isuzuperformance
7) Piper 2.25" exhaust system
8) Everest chip
9) Intake System and Compressor bypass valve from Top End Performance
10) Aluminum Radiator and Intercooler
11) Short throw shifter from Allan Betts Motorsport
12) SPAL fans
13) Aeromotive Fuel System with a Walbro 255 pump
14) Samco silicone coolant hoses
As far as a clutch is concerned, I want to go with a six puck sprung hub but am undecided between Unorthodox Racing and Spec. I also want a strong flywheel, but Fidanza does not make them for our engine anymore so I have found one by Aasco but am unsure of the quality of the product. I am also looking to upgrade the rear brakes with Hi-spec but am having trouble figuring out which of their product line I would need to buy to fit on the car. Looking for advice if anyone has fitted these products on their vehicle.
I am looking for suggestions on the upgrades I have planned and also looking for any additional advice anyone has to offer. If anyone has any other ideas for my project, it would be greatly appreciated. I am also not really concerned about price, I have pretty much an unlimited budget and am looking to buy the best for her.
davisfoo9
Re: Elan Autorcross Project-Help Desired
Postby racerstev » Mon 30.04.2012, 05:06
Good move overall but not sure if you want a heavier brake for autocross
I would raise the spring rates as well, stock is fairly soft
I never liked this idea, a standalone of something like a AEM FIC would work much better
4) Quaife LSD
For sure!
Not needed unless going for 500hp
I suspect you can get more performance from the stock turbo then you will ever
be able to put on the ground in a Autocross. There's only so much the front wheels can handle in 2nd gear.
Good move
8) Everest chip
Also good move
Agree, a bypass will help keep the turbo speed up
I don't think either will be of much help
I'd see Bob Brown for this one, don't forget the stainless cable upgrade
12) SPAL fans
Stock is fine unless they are dead
Don't think you will need this much fuel even with the turbo upgrade
Yeah pretty
You mean light flywheel?? For sure, it will help! I went with a stock pressure plate and a 6 puck, a little grabby but will hold alot of power.
I don't see the point of a rear brake upgrade, the rears on mine are almost turned off...
I am looking for suggestions on the upgrades I have planned and also looking for any additional advice anyone has to offer. If anyone has any other ideas for my project, it would be greatly appreciated. I am also not really concerned about price, I have pretty much an unlimited budget and am looking to buy the best for her.[/quote]
racerstev
Postby bobbrown » Mon 30.04.2012, 12:34
Expensive option as the kit is £1200.00 + VAT, the Hi Spec front conversion is worth considering as it is under half the price (starting at £420.00)
Not the best quaility dampers for the Elan, Nitron do a kit with a choice of springs.
Agree with Steve
4) Quaife LSD
Agree with Steve
Agree with Steve
Agree with Steve
2.5" if you are going for power
8) Everest chip
Agree with Steve
Agree with Steve
I may be a little bias but mine is better quaility and the short shift is now adjustable on the fore aft cable so the shift travel can be slightly shorter than standard or very short.
12) SPAL fans
Agree with Steve
Agree with Steve
Agree with Steve
Best option may be a two pot caliper matched to the fronts, bias pedal box with twin master cylinders and a spot caliper for the handbrake
You'll have to have deep pockets as this soon adds up
If you are looking at being competitive with other cars in your class you need to consider your opposition in the UK turbo cars have the engine size increased by a factor of 1.7 for the different classes so an Elan would be up with the big boys and do not think it would stand much chance of being competitive.
Pacific Blue N/A
Postby steve matthews » Mon 30.04.2012, 13:14
Last but not least the CV joints.
Steve
steve matthews
Postby racerstev » Mon 30.04.2012, 13:59
SCCA puts the car in A Street Prepared, it runs with pretty much the fastist street cars
on the road. If you come up ageinst a car prepped for the class I doubt you will
have much of a chance but you will still have fun!
Right Bob I agree, the larger exhust is the way to go.
One thing you don't look into and IMO the most important are the wheels and
tires. Will you be running a street tire class (wear rating no less then 140) or
a DOT race tire?
In my area we can run A/SP-ST or A/SP
Steve
racerstev
Postby davisfoo9 » Thu 10.05.2012, 06:06
Thanks for the advice guys. Think I'll skip the piston replacement and just get in there and replace the rings as they are surely old and worn.
Bobbrown, I have read on these forums that you do not sell your shift kit to the US. If this is untrue, I would like to look into it.
One other thing, does anyone know where I can get a rear upper strut bar for the car. I have not had any luck finding one anywhere.
davisfoo9
Postby bobbrown » Thu 10.05.2012, 08:42
Ring wear would depend on a number of factors and with modern materials they last a lot longer than people seem to think, 200k is not unreasonable if the mileage is towards the low side I would leave alone.
Do not know where that came from as I have supplied both cables and short shifts to the US only thing is the cables I source in the US with the rest of the kit shipping from the UK. I your case if you are in Hawaii then it may be more economic to ship every thing from here.
Personally I think a rear strut bar will do very much as the design at the rear is such that you can not get much if any movement on the top of the damper/spring.
Pacific Blue N/A
