steverob30 wrote:..... In this day and age, most simple camera pics are 1.5 - 3 mb in size and I simply don't have the motivation to resize every picture to 'fit'.
steverob30 wrote:Check your email
Brit-Car-Nut wrote:I don't see any M11 bolts from any of my suppliers. Are you sure it isn't a 7/16" bolt?
The better solution is to use a helicoil or nut-sert to restore the thread to the correct spec.
If you tell me which pictures you want posted, I can put them up for you. If you want to put captions, just send me a text file with a table like 1s: "Right Side View"
dapinky wrote:Steve - John (B-C-N) is correct - it isn't a clown, it was Lotus!
The early cars were built with M10 bolts, but it was decided along the way that bigger would be better.
M11 doesn't exist, M12 would be too big, but 7/16" is ideal.
Item 75 in the parts book is listed as either M10x110mm or 7/16 X 4 1/2".
I got a pair from Ebay when I did mine - but make sure that you get ones of the correct tensile strength - they have a different 'scale' to metric bolts, so you won't always find an 8.8, 10.9 grade etc..... (and obviously, you'll need nylock nuts to match)
Edit - try these 2 sellers....
http://www.ebay.co.uk/itm/UNF-7-16-Hex- ... HLvXz8Sujw
http://www.ebay.co.uk/itm/UNF-High-Tens ... zLg3S-8rmg
(the self-coloured ones are 'harder' than the bright zinc plated - grade 8 (or "S") as opposed to grade 5 ("A") )
