Grandpa's old M100 (White)
Recently I inherited my Grandfather's two beautiful Fed Spec Elans. He drove both of the cars daily for over 10 years, was constantly ordering parts for them, although only let his trusted mechanic do any serious work on them while utilizing my youth to teach me the less-than-serious jobs. This thread will only focus on the White as the Red M100 is its own can of worms.
Projects Completed:
-Oil Change
-Coolant Flush
-Thermostat Replacement
-Fuel Injector Cleaning
-Spark Plug Replacement
-Fuel pipe (From pump to fuel filter) Replacement
-Fuel Filter Replacement
-Potentiometer Replacement
-VSS Replacement
-Instrument Cluster Bulb Inspection/Replacement
-Battery Replacement
-Fuse Inspection/Replacement
Problems:
-ElanScan
I've scoured through the forums and have downloaded every patched version I could find to get the program to work on Win11 to no avail. Working on acquiring a Win10 laptop to hopefully get some scans!
-Tacho capping at 3k RPM.
This seems like a mechanical issue as there is a small silver piece showing where the needle stops rising. The engine continues to rev and it doesn't disturb the drive at all.
-Fuel Gauge reading 3/4 after a full tank
Read some helpful articles that suggest the bobber in the tank might have fuel inside. Not a real priority at the moment
-Dash not Illuminating* FIXED
When driving the highway at night, after cruising at 75mph I accelerate to ~85mph in 5th gear, and suddenly the lights on the instrument cluster and throughout the dashboard go dark. The Battery Voltage, Boost, and Oil Pressure gauges included. All of the other lights still work around the car (head/taillights) and even the headlamp pods are fully functional. This is an issue that has happened twice now, at the same place, around the same time, and on different days. I cannot diagnose a cause. After the first time this happened, I replaced the Potentiometer, and switched the Rheostat Control Modules between the Red and White cars and still no success. Switched back to the original Rheostat Control Module and then hand checked every wiring connection I could find underneath the dash. Checked the fuses throughout the car, all were healthy and in the right place. Feeling defeated because I never felt or heard any defining movement or click, I decided to test the illumination and THERE WAS LIGHT! I drove the Lotus multiple nights over the next week with the gauges glowing the classic burnt orange, and definitely over 85 mph. It wasn't until I was driving home from work (at night) at seemingly the same spot of highway at the same speed that the lights go out again! Very perplexing issue, how do I find a cause?
Projects Completed:
-Oil Change
-Coolant Flush
-VSS Replacement
Problems:
-ElanScan
