Hello from the colonies - project car by Lotusflight.
Postby lotusflight » Mon 10.03.2025, 21:14
New member here. Just got my first Elan - my first Lotus in fact. Project car. Looking forward to engaging here.
lotusflight
Re: Hello from the colonies.
Postby TorqueHorse » Tue 11.03.2025, 01:57
Howdy!
There are a few of us here stateside. Glad you found an Elan and have jumped in to it as a project car. This is the place to be if you are trying to keep your newfound love in top fiddle. We will all love to see photos of your car and the progress too (and answer questions along the way)!
'91 FED M100 -rolling resto
Postby FunElan » Tue 11.03.2025, 04:13
Welcome! Our cars are very specific, so if you have any questions don't hesitate to search first and then ask us here!
FunElan
Postby Tuga2112 » Tue 11.03.2025, 10:25
theres a few youtube sources that will be helpfull
most are UK cars but you sometimes find a FED example being worked on
thats my channel
https://www.youtube.com/@tuga2112
this is a very highly regarded channel by the comunity althoguht i dont think the guy is a member here. (or at least i havent seen anyone in this forum claiming ownership of the channel )
https://www.youtube.com/@thelotuselanm100restoratio3
ther's this idiot with a red car (FED car) with some intersting stuff... hes from the US and i suspect He has a black cat.... :poke:
https://www.youtube.com/@doubleshadowstar
Postby steve matthews » Tue 11.03.2025, 18:49
Welcome to the crazy house. :clap:
you must post pictures.
Steve
steve matthews
Postby lotusflight » Tue 11.03.2025, 19:22
I'll start with the gory details. It's been in storage for a while. It starts and runs, but cold start idle doesn't hold, have to rev it till it warms up and it sounds off - likely timing and possibly needs new plugs. So decided to replace fuel filter first.
lotusflight
Postby dunnlor » Tue 11.03.2025, 19:50
Welcome! Springtime has come to DC. A great time to be out and about.
I'm in Northern VA. Reach out to me if you need assistance.
Tom
dunnlor
Postby lotusflight » Wed 12.03.2025, 13:03
Thanks for the "welcome". Good to know we have some local owners in NOVA. I will definitely take you up on that offer, Tom. By the way, how do I access the wikilec? Is there a separate password I need for that?
lotusflight
Postby Fredjohn » Wed 12.03.2025, 13:54
lotusflight wrote:Thanks for the "welcome". Good to know we have some local owners in NOVA. I will definitely take you up on that offer, Tom. By the way, how do I access the wikilec? Is there a separate password I need for that?
Wikilec is currently down, but here is a link:
https://web.archive.org/web/20240511095 ... /Main_Page
Postby lotusflight » Thu 13.03.2025, 04:01
Toolkit was missing the penknife, so got the same style one that matches the car more or less.
lotusflight
Postby lotusflight » Thu 13.03.2025, 04:06
While I'm waiting for the fuel filter to come in, replaces the wipers and got some Rover parts cross referenced for the plastic caps to cover the wiper bolt/nut.
lotusflight
Postby lotusflight » Thu 13.03.2025, 04:11
Pulled one plug out to see if those need to be changed. What do you gents recommend for plugs upgrade?
lotusflight
Postby lotusflight » Thu 13.03.2025, 04:12
And the "under bonnet".
lotusflight
Postby FunElan » Thu 13.03.2025, 05:20
Making quick work - glad to see it. You're lucky you have the tool kit, mine seems to have disappeared!
FunElan
Postby lotusflight » Thu 13.03.2025, 11:10
I really welcome any comments or suggestions. This is my first project of this kind, so I know there is a lot that I don't know.
lotusflight
Postby FunElan » Thu 13.03.2025, 20:01
Since you're going to have the fuel system depressurized while doing the filter, it honestly makes sense to do the injectors at the same time. I know some here don't like fixing things until they're a problem, but it seems MOST of us have experienced an injector failure. They usually fail in pairs. You can have your originals rebuilt, or somewhere in the wiki is a link to the RC injector kit which is plug and play.
FunElan
Postby Tuga2112 » Fri 14.03.2025, 00:41
After having success with a fiat engine that has a single point injection system and using an off-the-shelf ultrasonic cleaner to recover a blocked injector.
My advice would be to take them out clean them all and put them back in don't spend money on something you don't need especially when it's something as expensive as injectors
Postby lotusflight » Fri 14.03.2025, 01:25
Tuga2112 wrote:After having success with a fiat engine that has a single point injection system and using an off-the-shelf ultrasonic cleaner to recover a blocked injector.
som
Oh. I'd be game to learn how to clean those. You mean something like this device?
https://a.co/d/gh9I8YF
lotusflight
Postby lotusflight » Fri 14.03.2025, 02:49
FunElan wrote:Since you're going to have the fuel system depressurized while doing the filter, it honestly makes sense to do the injectors at the same time. I know some here don't like fixing things until they're a problem, but it seems MOST of us have experienced an injector failure. They usually fail in pairs. You can have your originals rebuilt, or somewhere in the wiki is a link to the RC injector kit which is plug and play.
Good point. I would hate to find out that after replacing fuel filter and plugs, it still runs badly and would have to get the injectors addressed then. I thin I would like to keep to stock. Pretty sure this car has not been modified up to this point. And I honestly don't know yet what it does normally, so no idea about a baseline if I need a "boost" with the PL8-0550's and the new 3 MAP. If I were going to replace with the same injectors that it has, what would I get? (RC is an upgrade as I understand it from reading.)
lotusflight
Postby Tuga2112 » Fri 14.03.2025, 10:28
som
yes, but that tool is bit more heavy duty than the one i used, if you can afford to budgt for that, im pretty sure you will find other uses for it
