Simon_P wrote:Just fit one of Ron's chips and you have 200hp.
RonR wrote:I do have the code for a "No-Boost" version which opens the waste gate as soon as the turbo starts to spool - so probably around the same as the NA's 120 BHP......
Add a key switch and - Voila!
Tuga2112 wrote:i can see those cilinder sticking out. i dont think you will have problems, but keep in mind the clearance and particularly the fact you need more clearance to install it than it needs when its seated.
Tuga2112 wrote:im thinking specifically of a metal tube that runs along that area. i suspect it to be part of the crash structure. my recollection is that it looks pretty beefy material
Tuga2112 wrote:if voltage below x power up the white LED bank, if above the threshold power up the red bank.
id make the threshold be contorller by a potentiometer.
