Digital Gauges - Both CANBUS and Original VIN
Postby AJSGSE1990 » Wed 18.11.2026, 15:53
Managed to get these little touchscreen circular units off Waveshare along with a number of little other boards for regulated supply, canbus and more. They are about £30 each and are very easy to program via Arduino IDE.
The pictures here are running in SIM mode, standard Lotus, funs stuff, and backup clocks. I am also building a full digital dash which will run on an RPi 5. They are good but can be temperamental so a backup for revs, speed, and temp/fuel is needed. By the way the car's speed still comes from the original dash as the ECU can take in the optical pulses from the unit at the back of the clocks.
There is no reason why you could not replace them on a standard car and use voltage tables to give you readings. I have those in the ECU if anyone needs them as I already calibrated the original gauges. If anyone want to use my code feel free to ask.
Next is to buy a resin 3D printer and make the VDO gauge surrounds.
AJSGSE1990
