TheBard wrote:Last off, I really should wash her down this weekend. The rear is looking a little greasy and sooty around the exhaust. Again this is no real worry as she is running strong, and smooth, has no smoke on startup, or at any other time, isn't losing oil, and has no warning lights with all gauges reading normal. Anyway, she's always been a bit dirty after a few days hard driving since I cleaned the cat out.
Don't want to alarm you but a leak in my system, emanating from left hand side of the rad, was the first indication of a head gasket failure. It transpired that combustion gasses were passing from the cylinder into the water jacket and pressurising the system beyond its capacity, forcing coolant out. There were no other apparent signs, oil or water contamination other than the release of pressure when the header tank cap was released. Hope yours is a more straight forward explanation!
TheBard wrote:
On the to-do list:
#1. Fit Marie's roll bar.
#2. Fit new louder air-horn to allow me to scare small children and 18 wheelers.
#3. Wash the car when it warms up a bit outside!
TheBard wrote:Get home, swear at the car and dismantle the door. Turns out the plate that covers the window cable on its circular gear has lost the screw.
The window repair will be a higher priority too...
Ekapol, wanna come and rebuild another window motor?
