Interior Door Handle Escutcheons Made New
Postby Andy_R » Mon 07.11.2005, 00:56
After realising that I was never going to find a replacement for my broken ones, I decided to have a go at reparing them - as it turns out, to very good effect. It cost about £8 ($15) and not too many hours. Patients and attention to detail are all that are required to get a good result. Have a look at the before and after photos below.
First step is to go to the shop and get a small tube of body filler (the make I bought was 'plastic padding'), some wet and dry paper/sand paper, a can of plastic primer spray paint and a can of Halfords Rover Hurricane grey spray paint. I specify Halfords because Rover Hurricane Grey differs according to the manufacturer.
Apply a 'blob' of body filler where your escutcheon is missing a bit of its plastic. For those who haven't used the stuff before, you mix the filler with a hardener before applying - I recommend using alot of hardener to speed up the drying process. Speed up the drying further by baking in an oven at about 100 degrees C (that's 212 F for you lot over there).
Once your 'blob' has hardened (several hours at least) you need to chop away at it with a sharp knife to get it roughly to the desired shape. It's not difficult to detach your 'blob' from the escutcheon plastic which you will no doubt find as annoying as I did, so don't chop too hard, and make sure the knife is sharp - a paper knife will work well.
When you have something approaching the right shape, start using progressively finer grades of sand/wet and dry paper to fine tune the shape.
I found that I had tiny chips in mine at this stage; I also found that the shape I had wasn't quite perfect, so to get over this I mixed very small amounts of body filler and applied tiny amounts to the imperfections to correct them. This is where the patients comes in - because the body filler takes time to dry, it may take 2 or 3 days before you finally get a good smooth finish. Make sure that if you see any imperfections no matter how small, you take the time to sort them out - after you spray paint, small imperfection become much more noticeable.
When you are absolutely sure that you have a perfect finish, check what you have created fits nicely back into position in the door, then take them out again to be painted. For tips on how to paint, read the back of the can. Again, don't rush the process.
I'm alot happier sitting in my car now - I actually think that the Rover colour (color), close though it is, is better than the original.
Hope this stops a few of you loosing sleep over bits that you'll never find. If you want any more help, send a PM.
Andy
Before
escutcheon before.jpg (49.11 KiB) Viewed 3204 times
After
escutcheon after.jpg (49.79 KiB) Viewed 3204 times
Andy_R
Postby Houdini » Mon 07.11.2005, 06:01
Fing A!!!!!!!!!!!! Good work!
Houdini
Postby Doc Fizzix » Mon 07.11.2005, 14:40
Very nice! :D
I had thought about trying the same, I have one that is bad. You have inspired me.
Good work :D
Doc Fizzix
Door Handle Plate
Postby johnbenk » Wed 09.11.2005, 23:05
Hi
Why dont you colour code them as well? see thread: Colour coding the interior of your Lotus Elan :D :D :D :D :D :D
johnbenk
The only Gay in the Village
Postby Andy_R » Thu 10.11.2005, 23:34
Where's that thread John? Can't find it!
Andy_R
Postby GeoffSmith » Sat 18.08.2007, 12:09
Now on WikiLEC.
Users browsing this forum: No registered users and 17 guests
