dapinky wrote:When mine went wrong I managed to fix it (just came undone) so never got any of the uprated cables...... and the set of AB cables I did have ended up being fitted to a yellow elan up in Scottishland
Rambo wrote:dapinky wrote:When mine went wrong I managed to fix it (just came undone) so never got any of the uprated cables...... and the set of AB cables I did have ended up being fitted to a yellow elan up in Scottishland
CalElan wrote:On my Fed car the internal lights stay on for a little while OR until I insert the key --- If I remember correctly.
muley wrote:You think the timing belt is slipping? I suggest you get the cambelt cover off and check. Put no. 1 cylinder to tdc using crank pulley mark and ensure marks on camshaft pulleys are aligned, with the tensioner firmly holding the belt in place. In my experience the car will run quite well even if the belt is 1 or 2 teeth out.
) RonR wrote: If the system's been dry you might find the proportioning valves also need some persuasion to give up their air.
Tuga2112 wrote:do you mean to just bleed the rear and let a lot more fluid run through the lines ? or something different ?
