Re: Small (or maybe not) project. 91 elan
Postby dapinky » Sun 21.03.2021, 13:41
Joao,
From the picture, most of the back section looks pretty solid to me. I'd consider removal of the base part either by unscrewing the bolt from underneath (not likely to be easy!), or simply destroying the threaded 'plate', and removing the bolt. You can make up another plate with a flat piece of steel and an M12 (IIRC) nut welded to it.... or even sandwiched between two steel plates, and welded up solid.
With that out of the way, you should be able to get to the rotted bits of steel behind it and get to clean(ish) metal.... then put the new 'base' in the right place, stick a stainless bolt up from underneath (you can use any type but I used ones with cheese heads and allen key holes, and hold it in place while you weld the new bits to the back plate.
Once that is welded up you can build the side pieces back with either new metal or weld..... be careful not to weld the bolt to the threaded bit, or it will be there forever.
The top bit is easy to get at, and the front plate can be spot welded (or actually plug-welded is easier unless you have a spot welder) after spraying it with wayoyl (or similar). When it is solid, it doesn't matter what it looks like as it all gets hidden anyway - and the front panel can be built up either as one piece or in sections, as long as it attaches to solid metal at the front and rear.
Bear in mind that the whole point of it is to have something solid to lift the car for a wheel change - not to look pretty - so solid welding is what we are aiming for, not beautiful artwork which may fail!
Postby Fredjohn » Sun 21.03.2021, 15:38
Notwithstanding Dave's comments above, if you do need to cut back any further and can't use an angle grinder, have you thought of using a multi tool? Put a steel cutting blade on and they will access almost everything.
Nice work so far. Very brave of you! Just hope I don't have to do it!
Postby Tuga2112 » Mon 22.03.2021, 20:27
Thanks for the suggestions.
removing the bottom plate was a very dificult task, I ended up cutting a bit into the threads of the bolt, which leads me to wonder if any M10 alen head bolt will do to replace or if i really need to buy the lotus specific one
I Have a very strong replacement piece of metal ready for the base.
At the moment i'm not decided as far as rebuilding the support with weld VS new metal. I have spare metal of a few different thinknesses. some much thicker than the original metal, however the most practical one I have at hand is a .9mm thick sheet of zinc plated steel, which i suspect is thinner than the original metal.
I will be digging my multi tool box to see if i got any metal cutting attachments.
im going to return to work on it tomorow after work.
Postby dapinky » Mon 22.03.2021, 20:54
The bolt doesn't need to be specific Lotus one - I used a 'normal' one from my selection in stock..... Just make sure that whatever is left sticking out the bottom of the car will engage in the standard jack, as that is what it is designed for!
As far as material to weld up, I would suggest something like 1.6mm steel...... if you do use galvanised, be a bit careful when welding - the fumes from the molten zinc are toxic (even in small doses).
Postby Tuga2112 » Sat 27.03.2021, 12:39
Got a question that may deserve its own topic,
I See it mentioned in the forum and the manual about Butyl and Sikaflex as the main 2 types of sealants used to glue panels (eg. clam shell to body) and seal against water ingress (trim plastic under the door and glueing other seals with the body)
Since im in the process of taking everything apart and putting it back together in the Car, Id like to know what Other people use and what they recomend I should be using from the toolstation or screwfix range for those purposes.
Things i need to put together include
metal to fibregalss
(Where i am Repairing/rebuilding the front jacking points and outriggers )
plastic to fibreglass
(b post interior trim panels, the trim panels under the door.)
rubber/foam TO FIBREGLASS
(hood stowage compartment seal to the bodywork )
Carpet to bodywork
(pretty much all the carpets in the car have been removed)
Postby dapinky » Sat 27.03.2021, 17:35
Joao,
Where 'sikaflex' is mentioned, it can be taken to mean any suitable high-strength polyurethane adhesive - Sikaflex is simply one brand. Another well-known brand is Tiger Seal, but I use Pu18 which is easily available from ebay.
Where butyl is mentioned, it is a form of flexible gooey stuff which comes in a roll - again, I buy from ebay, but it is used in roofing for joining metal, so can be bought in any builders merchants. It is available in either 'round' or rectangular cross-sections in various sizes, and you simply mold it to fit.
For fixing the underlay and carpets, a simple 'spray adhesive' like this one from Screwfix is fine.
Basically, Pu adhesive is for high-strength things (sill metal to fibreglass etc) where you are unlikely to ever want to dismantle it again. It cures with water in the air, so can be used where the things to be joined are either damp already, or likely to be subjected to damp. (Lotus use it to join body sections).
Butyl strip can be separated at a later time as it never truly sets, and although it will skin over, it is always flexible.... good for fixing things like the sill plates which need to be removable but watertight. Also used for fixing the rubber seal to the rear deck, fixing things like the speaker housings in the doors and the access cover panels in the doors.
Spray adhesive does what it says on the tin - good for carpet fitting.
Postby Tuga2112 » Sun 28.03.2021, 13:09
Thanks for the overal guidelines and suggestions Dave.
The Butyl strip seems something of a different style than what Jamien_N suggested i used when fitting the header seal. I Was expecting something of the same style as the silicone gun dispencers to be used to handle the butyl sealant .
On a annoyinly different note .
The Rear part of the outrigger Behid the B Post Interior trim PAnel on the passenger side is gone to the tin worm.
The rust is creeping into the seatbelt bolt at the back (pretty close to the fuel tank).
I can paint the existing rust with hammerite and hope the rust stops spreading. OR alternatively remove the fuel tank and weld new metal.
I Dont want my "2021 respray" task to project creep into a major project thread. but at the same time. I have a preference to deal with it now instead of taking the whole car apart again in 2-5 years time to deal with it.
The Fuel Tank on the car is nearly Full. draining it is not a big problem since i would be draining it to a jerry can and fill up the other car in 8-12 runs
Im looking for tips and tricks on how to proceed. most importantly refering the fuel tank removal part of the task
Im going to leave this post unfinished for the moment as i intend to ask a question on the outriggers post that will be related to my decision making on this
Postby Tuga2112 » Sun 11.04.2021, 00:11
as far as repairing the front passenger jacking point. this is the video on the topic.
this video is the same as the one you can publicy see in my channel, but exclusively released for the forum
I need to do another video on the clam shell fixing removal (all the rusty bits) And after that one is finished im goin to remove the rear suspension, fuel tank, and finally address the rear of the outriggers as previsouly described.
i wil be updating things here as progress is made
Thanks for all the help guys. :-)
Postby Rambo » Sun 11.04.2021, 07:37
Excellent work João :bowdown:
Postby tb10 » Sun 11.04.2021, 08:45
:agree: Splendid!!
tb10
Postby Kipperozzy » Sun 11.04.2021, 11:57
Great job and video, no wonder this forum is the dogs bollocks :clap:
Kipperozzy
Postby Simon_P » Sun 11.04.2021, 19:28
Nice Video - thanks Joao.
Postby Steve A » Sun 11.04.2021, 23:49
:clap: well done Joao, and for taking the time to film, edit and post it :bowdown:
Postby muley » Mon 12.04.2021, 09:59
:bowdown:
Excellent job.
Thank you.
Postby Rambo » Mon 12.04.2021, 10:46
Rambo wrote:Excellent work João :bowdown:
Next time you make an excursion to Scotland João bring your welding gear and some metal. I can arrange some work for you. Free use of The Bothy, food and beers included. We can also spend more time exploring the fantastic country roads in Jim Clark territory :burnout:
Postby dapinky » Mon 12.04.2021, 11:30
Following discussion with Joao, and notwithstanding that he is the owner of the video(s), LEC are pleased to be able to host a copy of this excellent tutorial in the 'Manuals' section, and which we hope to add to in due course.
We will NOT be hosting every video produced, and due to file size restrictions, they will be in a Web Format, not in HD......
.... so if you want a general idea of what is involved, look here, but if you want full Cinematic experience and the ability to leave appreciative comments (plus see the full selection of tutorials), then go to João's channel on YouTube at:-
https://youtu.be/VUH5dKS716E
Postby Tuga2112 » Mon 26.04.2021, 19:53
Although the work has been done a month ago (or even more) These are the videos of the other work done that has been released on youtube so far.
Removing the Bonnet
Removing the Headlamp Pods
Removing the Front Bumber
I wont be posting on the forum everytime a new video is released because i have them all scheduled for every Saturday for the next 2-3 months.
I'm still in the process of editing other Videos before fixing the rust on the rear of the outriggers.
Postby Rambo » Mon 26.04.2021, 21:20
Well done João :bowdown:
Postby Tuga2112 » Sun 02.05.2021, 12:39
One is out, Looks like plenty of surface rust.
Brake lines broke in order to remove it (couplings seized). but apart from that it was not the problematic type to come out.
i was originally thinking of zinc plating it, But I dont know if the solution would destroy the bushings, and where/how much replacements would cost.
im going to give this one a good cleanup before deciding if it can be plated or if im going to end up coating it with hammerite to protect it for another few years
Postby dapinky » Sun 02.05.2021, 15:32
Joao,
Zinc plating comes in 2 flavours - electroplating, and galvanising.
Galvanising involves dipping the metalwork in various chemicals to clean it up, and then into a hot bath which gets the zinc to stick to the steel.
I would think that the 450C required for galvanising would have a detrimental affect on the bushes (as well as covering them in molten zinc!) - so to do it would require removal and later replacement of the bushes..... also, as the steel will be somewhat weakened/thinned from aging, it may well cause the wishbone to deform (but I've never tried it, so am just guessing)
Electroplating involves a much more scientific method of coating at 'normal' temperatures, but because of the size and shape of the wishbone, I don't know how even a coating it would provide due to the localised electric current.
Personally, I'd give them a good clean, then soak them in phosphoric acid to kill/convert any remaining rust (including the inside surfaces)...... then paint them with chassis paint (or even Zinc paint).
Users browsing this forum: No registered users and 14 guests
