Head gasket - Yes or No?
Postby muley » Thu 19.03.2009, 20:22
So, I'm halfway through the turbo and cambelt job and it suddenly struck me - should I change the head gasket?. At this stage I've still got the crank pulley off and the exhaust manifold is off.
Car has 93,000 on the clock and a patchy history.
What does the LEC massive think - should I do the head gasket as well while I'm here ?
I am already going to replace the fans and hoses btw.
[homer simpson voice]
Lousy project creep
[/home simpson voice]
Re: Head gasket - Yes or No?
Postby Enright » Thu 19.03.2009, 20:27
No. In fact HELL no! You don't want to disturb that lot if you don't have to.
That's one job where if it ain't broke you don't want to try fixing it - leave well alone.
Postby Doc Fizzix » Thu 19.03.2009, 20:33
Enright wrote:No. In fact HELL no! You don't want to disturb that lot if you don't have to.
There is an old saying that I have learned over and over again and in moments of weakness I screw-up again and forget what I have learned:
"If it ain't broke, don't fix it!"
Doc Fizzix
Postby Monty » Thu 19.03.2009, 21:48
Jim, thats a bloody good question.
and i`d tend to side on the Yes, thats if your doing it your self and it will only cost you the price off the Head gasket :?
The reason i say this is that i believe there`s many Elans out there that have a HG failing and don`t know it, mine only showed up when i started doing trackdays and only then i only got a slight rise in coolant temp but it caused my Rad to leak :evil:
It`s a tough decision.
