Engine Rebuild and T-bird turbo
http://picasaweb.google.com.tw/m100s2/307RepairACUTUAL#
My S2 engine was in decent condition. I had driven about 5000miles in the past 3 years.
In this time period, I changed oil very often because there was some noise coming from the engine.
I decided to rebuild this engine because I had purchased a spare engine some time ago. Engine parts were no problems.
I show you all some pictures before the REBUILD.
Note: You can see a hole in the big end bearing shell. For a turbo conn rod's big end bearing shells, there should be plain bearing shells. I did consult other engine rebuilders and asked them whether it is forbidden to install that kind of bearing shell on this particular conn rod's big end. They all commented that it should not matter in this particular case.
KMC Engine Rebuild Project:
Replace a new S2 steering rack : POW-A_RAK Installation done.
Recondition alternator: Recondition done.
Replace ball joints: Replacement done.
Recondition engine cylinder head: Recondition done.
Rebuild cylinder block:
Adopt T-bird turbo:
Port waste gate to 20mm: Ported.
New gear lever (shifter): installed. It's like shifting a new car!
Replace ASM water by-pass turbo PIPES (in stainless steel)
Adopt T-bird turbo:
soon be back on the road
