LED DRL's and 3rd Brake Light
Postby jHamshaw » Mon 06.06.2011, 17:29
Living as I do in the murkiness of Norfolk (even on good days such as last week you're in and out of shadows all of the time on the best roads) and on the basis of if you can't beat 'em, join 'em with all new cars since March 2011 being fitted with them as a legal requirement, I'm trying out some LED DRL's on my new (to me!) S2. Whilst fully appreciating that many of these can look downright awful, I wanted something that looked right, and was fully reversible. I went for a set of these (they're all over eBay at present - look for "Mercedes Style DRL's") which are only 15mm high, fit the outer grille apertures almost perfectly (admittedly upside down!), don't block too much airflow and, best of all, are fully reversible/removable :-
Fitting pictures (wired with a relay so on with ignition, and off when sidelights/headlights switched on for MOT compliance) :-
DRL's Off
P6040013 (Small).JPG (72.78 KiB) Viewed 4655 times
DRL Detail
P6040014 (Small).JPG (64.34 KiB) Viewed 4655 times
Dusk pictures (difficult to photograph bright LED's - they either over or under-expose) :-
DRL's On
P6040017 (Small).JPG (58.41 KiB) Viewed 4655 times
DRL's On
P6040021 (Small).JPG (68.33 KiB) Viewed 4655 times
To compliment these I wanted a 3rd brake light, having great faith in these over the years on other cars since their introduction. Again, I wanted something discrete and reversible so used a piece of self-adhesive LED strip, with the LED's mounted to project sideways :-
3rd Brake Light Off
P6040015 (Small).JPG (72.58 KiB) Viewed 4655 times
3rd Brakelight Off Detail
P6040016 (Small).JPG (57.87 KiB) Viewed 4655 times
3rd Brakelight On
P6040019 (Small).JPG (68.93 KiB) Viewed 4655 times
3rd Brake Light On
P6040020 (Small).JPG (52.07 KiB) Viewed 4655 times
Comments welcome - I do appreciate that this is probably a "Marmite" project but it's all reversible and the safety aspects are what matter to me....
jHamshaw
Re: LED DRL's and 3rd Brake Light
Postby RayD » Mon 06.06.2011, 18:38
It looks very good Jim,
Is the LED strip the same as I used on here?
Postby jHamshaw » Mon 06.06.2011, 19:14
RayD wrote:It looks very good Jim,
Hi Ray, and thanks!
Not quite the same strip : cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230578471945
jHamshaw
Postby Enright » Mon 06.06.2011, 21:22
Very, VERY good job. Well done. :clap:
Normally I hate aftermarket lights, but I think they look really impressive.
Postby trig » Mon 06.06.2011, 22:10
Although the Elan is over 20 years old it does not look it,, and the odd modern enhancement doesn't look too out of place..Like it :clap:
trig
Postby cliff » Thu 09.06.2011, 00:04
Undecided on the DRL's but really like the brake light.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby jHamshaw » Thu 28.07.2011, 17:18
UPDATE - both DRL units have now failed - one with water ingress, and one with a burnt out LED - I can no longer recommend these units from a quality standpoint - shame as they fit so well!
/Off to find replacements as the wiring and relay are still good.... :banghead:
jHamshaw
Postby a5gcd » Tue 09.08.2011, 20:04
jHamshaw wrote:UPDATE - both DRL units have now failed - one with water ingress, and one with a burnt out LED - I can no longer recommend these units from a quality standpoint - shame as they fit so well!
Have you found a replacement yet?
a5gcd
Postby jHamshaw » Wed 10.08.2011, 13:17
Yes :-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150535320910
jHamshaw
Postby tweetdriver63 » Thu 11.08.2011, 01:14
Yes :-
I have similar ones on my car. I don't have them wired as DRLs though, since they really don't put out enough light to be of any use in the daytime (at least, not the ones I got). I have them spliced into the side marker lights to add to my visibility (others seeing me) during those times when I don't need the headlights on to see, but have the marker lights on to be seen.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby jHamshaw » Thu 11.08.2011, 09:30
That's illegal/an MOT failure in the UK! :roll:
jHamshaw
Postby rip » Thu 11.08.2011, 10:55
Which is crazy. There are a lot of mad things creeping into the UK's MOT.
