Supercharger anyone thought of fitting one?
Postby abmunro » Sat 16.04.2016, 11:06
Has anyone ever thought of fitting one of these instead of changing Turbo?
I'm trying to reduce my lag.
I've been looking at Miata conversion on the internet
But don't know much about it.
Any ideas anybody?
abmunro
Re: Supercharger anyone thought of fitting one?
Postby GeoffSmith » Sat 16.04.2016, 11:23
Surfboardfiller.
Postby Tuga2112 » Sat 28.05.2016, 22:16
GeoffSmith wrote:Surfboardfiller.
are you sure he looked into that ?
From the few conversations I had with him, I cannot recall a supercharger ever being mentioned.
Postby Rambo » Sat 28.05.2016, 22:25
viewtopic.php?f=31&t=19877&p=254785&hilit=Supercharger#p254785
Postby GeoffSmith » Sat 28.05.2016, 22:27
:agree: :smt033 :smt116
Postby Tuga2112 » Tue 31.05.2016, 21:36
a small but interesting read.
as far as im aware, ac systems require a compressor powered by the same belt as the pas.
pluging the supercharger into the slot of the air con could work i suppose, that would allow it to be run from the main belt... which could rule out the issues with running an electric?
if you can get one compact enough to fit? (my ignorance stops me from helping much)
im assuming what stopped the plan was something more complex than my understanding of the topic allows any helpful input .
Postby rip » Wed 01.06.2016, 12:10
Tuga2112 wrote:as far as im aware, ac systems require a compressor powered by the same belt as the pas.
Yes, but how much power do the 2 require to power? This would need to be answered before anything else is considered. I suspect a supercharger would require significantly more power than an air con compressor.
Tuga2112 wrote:pluging the supercharger into the slot of the air con could work i suppose, that would allow it to be run from the main belt... which could rule out the issues with running an electric?
But if the supercharger consumes significantly more power than the air con compressor, the existing belt would be unsuitable & you would have to find an alternative way of driving it. My previous question would need to be answered first.
Then you would have to find somewhere to fit it, if you can.
Then plumb it in.
Then control it, because the ECU's memcal would not know how.
Then hope that it works. If it doesn't, you will have spent a lot with potentially little, none or even negative return.
