Replacement Outer Door Strips from PNM
Re: Replacement Outer Door Strips from PNM
Postby KevB » Tue 25.02.2014, 12:53
Yes please, one pair, mine are shot!
can you hold till Friday? cash flow problem :roll:
Kevin
KevB
Postby dapinky » Tue 25.02.2014, 13:24
Kev,
I've held them for 6 months, so a bit longer is no problem at all!
Logistically, I am off to Vietnam on Friday, and not back until 19th March - if you are happy to wait, we can sort it all out when i get back, but if you have seen a rare glimpse of sunshine and want to get on with the job, then just PM me your address and I'll get a set out to you before I go - we can sort the payment later.
Postby abmunro » Thu 07.12.2017, 23:10
[quote="Brit-Car-Nut"]PNM has offered LEC a one time discount for the weather strips if we can order more than 25 sets. This only came about after so many were asking for replacements.
A set or a pair is both sides or enough to do the entire car.
Go to the bottom of this page: http://www.pnmengineering.com/lotus-bodywork-chassis.html
Wienlot made the introduction for LEC and PNM has been very generous in making their offer.
Everyone needs to take a look at their strips and decide if they need/want a new set.
If you want to see how to get to the strips to replace them, see http://wikilec.9600.org/index.php/Door_Trim.
Also http://www.lotuselanm100usa.info/lec/Door%20Card%20Removal-1.pdf
and http://www.lotuselanm100usa.info/lec/Door%20Card%20Removal-2.pdf
have decent pictures and descriptions of how to get to the seals.
The links don't work anymore, does anyone have working links?
Tony
abmunro
Postby Fredjohn » Fri 08.12.2017, 00:03
abmunro wrote:The links don't work anymore, does anyone have working links?
Tony
Easy: go to PNM site and search for weather strips or look here
Brit car nuts website has moved I think: check at the bottom of his posts for the new link, also here
WikiLEC link: go to wikiLEC tab at top of page and then look for door glass weatherstrips or try this link
LEC solves another problem!!!!
Postby Brit-Car-Nut » Fri 08.12.2017, 06:37
The basic file (combined) is now listed in the Manuals site as well as Specky's guide to remove and replace the window motor.
http://www.lotusm100.com/manuals/Door-Card-Removal.pdf
http://www.lotusm100.com/manuals/Specky ... Repair.pdf
I tried to consolidate and relist any guides, manuals or other helpful articles I found that looked to be helpful.
Just go to http://www.lotusm100.com/manuals and look through the index.
Postby abmunro » Fri 08.12.2017, 06:51
Thanks Guys!!
abmunro
Postby Steve A » Fri 08.12.2017, 14:00
I did the "Gordon conversion" years ago, as long as you use a good glue (I used Q Bond) it's not too difficult.
Even after all this time none of my tabs have come off.
Above is the Honda seal (via Jamie) which I'm currently working on.
