Rear Hub/Disc conversion second run + Hi-spec brakes
Postby bobbrown » Fri 20.03.2009, 23:25
As some people have expressed an interest in the rear hubs having missed the first run I am going to start a second list.
I can then see depending on numbers how it equates with regards to the price but I feel that I may be able to get them made for around the same price as the first run provided I am not only looking at a couple of sets.
The first run was £130.48 inc vat plus delivery
When you look at the price and compare the cost of new standard discs £170.00 ish it become favorable as you only need a pair of low cost GM discs.
Can not start the list with me as I have them all ready.
Pacific Blue N/A
Re: Rear Hub/Disc conversion second run
Postby lotos » Fri 20.03.2009, 23:52
Is this required if you want to upgrade the rear calipers?
lotos
Postby bobbrown » Fri 20.03.2009, 23:58
lotos wrote:Is this required if you want to upgrade the rear calipers?
This is a requirement if you want to upgrade the rear calipers to Hi-spec 2 pot but can only be done if the fronts have been upgraded first and can not be done with the Wilwood 15" kit as it does not increase the front braking enough.
Pacific Blue N/A
Postby max and andy » Sat 21.03.2009, 00:12
Very interested. What sort of time frame are you thinking.I have the fronts to get as well. It is the two piece kit ? Max :banana:
max and andy
Postby bobbrown » Sat 21.03.2009, 00:36
Time frame is numbers dependant.
This is a list for the Hubs only which can with the addition of a low cost disc be used with the current caliper.
I would like to keep the two seperate.
Pacific Blue N/A
Postby alexg » Sat 21.03.2009, 00:43
Ok I'm in and will start the list
1. alexg
alexg
Postby Jimmer » Sat 21.03.2009, 17:59
Hey Bob,
I don't need to tell you I'm interested, but a question if I may:
Would you recommend enlarging my front discs to suit the rears (mine is the Hispec upgrade to suit the 15" rims). This is an option as it looks like I'll soon be getting a set of S2 alloys. If so, are the calipers still suitable if I get the appropriate brackets or does the whole lot need to change?
BTW, I saw AndyP yesterday so I have my pads now. He kindly offered to bring back the wayward pads and post them to you when he returns.
Jimmer
Postby bobbrown » Sat 21.03.2009, 18:39
Jimmer wrote:Hey Bob,
There is not a lot in it as the 15" brakes, needless to say, will fit under the S2 rims.
The 16" kit does increase the brakes by about 7.5%, which is only really felt in terms of pedal input.
The 15" kit will still be more than adequate to stop the car, in fact the limitation will be the tyres not the brakes. As for the rears the only differance would be in the size of the rear discs 16" fronts uses a 256mm diameter rear disc and the 15"kit uses a 240mm rear disc.
If you wanted to change to a 16" kit then the discs and caliper brackets would need to be changed every thing else remains the same.
Pacific Blue N/A
Postby bobbrown » Sat 21.03.2009, 18:40
the list continues
1. alexg
Pacific Blue N/A
Postby whippit » Sat 21.03.2009, 19:24
I'de like to add my name, but cannot figure out how :oops: ,
ive pressed nearly every button and failed , i hate bloody computers
whippit
Postby Jimmer » Sat 21.03.2009, 19:36
bobbrown wrote:the list continues
1. alexg
2. whippit
3. Jimmer
Jimmer
Postby martin_bailey_1 » Sat 21.03.2009, 20:14
Very timely ! my rear disks are in poor shape, so shiny new hubs and (cheaper) replacement disks sounds pretty good to me :D
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
martin_bailey_1
Postby max and andy » Sat 21.03.2009, 20:16
Max & Andy . Thank God there's someone else whippet.
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
max and andy
Postby Andy_J » Sun 22.03.2009, 09:52
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
90H BRG SE 48,000 Miles
Andy_J
Postby dapinky » Sun 22.03.2009, 15:38
I know that this is a 'list' thread, not specifically an 'information' one, but it may help people on the list, or from the first buy.....
The disks required to fit the 'standard' rear brake calipers (and these hubs) is an Apec DSK117.
If you still have standard front brakes, the front discs used are Apec DSK518.
I had a set of 4 from www.thehappymotorist.co.uk for £44.03 inc VAT and delivery :D
front (DSK518) are listed for a Vauxhall Cavalier 2.0 ('88-'95) at £12.03 each.
rear (DSK117) are listed for a Vauxhall Astra 1.4 ('91-'98) at £6.51 each.
They arrived within 48 hours, and the company (as well as being the cheapest 'All In' price I could find) were easy & helpful to deal with.
Sorry,
You can have your list back now :D
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
Postby BFG in the BRG » Sun 22.03.2009, 16:18
My rear disks have just failed the MOT - excessive corrosion on the inner face :twisted:
Cost to replace in total, including reconditioned disks, new bearings, and pads from SJ's £140 ish, although I was minded to do the bearings anyway since they've been in for about 10 years.
I reckon the reconditioned disks may rust a little faster than new - (dunno why :roll: , I just do)
I'm sorely tempted with this, since in future all I would need to do is replace the disks.
So.....Bob or anyone.... any idea whether I will be able to use the same new bearings? :shock:
Alas soon to be Elan-less
BFG in the BRG
Postby bobbrown » Sun 22.03.2009, 17:15
The DSK117 is not limited to the Astra and is available for a range of Vauxhall cars plus one Daewoo model.
Ascona 79-84 F Astra 79-98 F Astra Estate 91-98 F Astra Van 82-98 F
Astramax 85-91 F Belmont 86-92 F Cavalier 81-91 F Corsa 93-00 F
Corsa Van 94-00 F Kadett 79-84 F Nova 89-93 F Nova Van 90-93 F
The rear wheel bearings are exactly the same as the original disc/hub.
I did source a SKF bearing that fits see http://wikilec.9600.org/ and if needed I can supply these at around £24.00 an axle set, thats two wheel bearing kits. but that price is a little numbers dependant.
The total cost of hubs, discs, bearings and pads should be around £210.00 as apposed to £240.00 if using the original disc/hubs (new) and in the future the cost to replace discs is significantly reduced
the list continues
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
Pacific Blue N/A
Postby Exbury » Tue 24.03.2009, 19:51
Is there any photos of this conversion by any chance, especially if compared to the original? I am wavering at the moment - ( I have the standard rear callipers.
Ta, Jason
Exbury
Postby bobbrown » Tue 24.03.2009, 20:52
Some pics
Hub on carrier
Hub
Hub with disc for standard calipers
Hub with 256mm disc (same as original front) for Hi-Spec upgrade
Custom setup hat/bell for Elanlover 273mm Wilwood rear disc (315mm fronts)
Hope that was what was wanted
Note: This works out a lower cost option when replacing the rear discs and in the future you only have to replace the discs which are cheap sub £30.00 the pair if using the standard caliper.
Pacific Blue N/A
Postby ab2cv » Tue 24.03.2009, 23:58
I've been away from the forum for a while, so there's been a LOT of reading to catch up on! This looks like a really well thought out and engineered modification. Well done that man Bob :) . Still catching up on other threads regarding front/rear brake upgrades, so more reading required, but in the meantime......I'm in!
the list continues
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
7. Alan (ab2cv)
Yellow Esprit GT3
ab2cv
