PIPES, ASM Water By-Pass TURBO in Stainless Steel
Postby kmckmc » Fri 10.04.2009, 07:15
Currently, my Elan M100 S2 is undergoing a major engine restoration.
http://picasaweb.google.com.tw/m100s2/307RepairACUTUAL#
My mechanic told me it is about time to replace those 2 ASM Water By-Pass Turbo PIPES.
A100E6338S and A100E6362S
I was informed that A100E6338S pipe is about £270. Dave Bean sells one for about 500+ USD.
As you can see from the picture, the top pipe has one end which is attached to a Suction PIPE (A100E6334S). This suction pipe (about £25) is a 3-way pipe. Also, an O ring is needed; A100E6339S at about £1. My M100 S2 was made in 1995. I suppose it is about time to replace them. I can see rust buildup inside the pipes.
So, I have asked my mechanic to make those 2 pipes in stainless steel. Would you be interested?
I would like to see if I can get another 8 sets going. About the price, he has not told me yet. My reservation price is about £120. Is that too much for 2 pipes in stainless steel? I should know the price soon.
This is for gauging LEC members' interest in those pipes ONLY.
1.kmckmc
2.kmckmc
3.
4.
5.
6.
7.
8.
9.
10.
Elan M100 S2
kmckmc
Re: PIPES, ASM Water By-Pass TURBO in Stainless Steel
Postby woody » Fri 10.04.2009, 07:33
I'm interested.
1.kmckmc
2.kmckmc
3.Woody
4.
5.
6.
7.
8.
9.
10.
Cheers,
woody
Postby Jimmer » Fri 10.04.2009, 15:34
Sorry if this sounds dense but, just to clarify:
A100E6338S = long bypass
A100E6362S = short bypaas
A100E6334S = suction pipe
Am I right in thinking you plan to get the long bypass from Dave Bean and have the other two fabricated?
I assume Dave Bean sells the original (mild steel) long bypass?
I'd be interested in getting all three in stainless.
I was hoping to start a group buy for the long bypass myself as I've just had the garage make one up for me. I asked for stainless but as it came back painted, I assume they used lead.
Jimmer
Postby kmckmc » Fri 10.04.2009, 16:51
Hi,
I am assessing LEC members' interest in the set (1 long ASM by-pass pipe and 1 short ASM by-pass pipe; all in stainless steel). If the suction 3-way pipe can be made in stainless steel, I will let you all know.
Lotus OEM ASM by-pass pipes are expensive. I do not plan to buy them. That is why I want to custom make those pipes at less than half of the Lotus price.
Elan M100 S2
kmckmc
