by ashm » Mon 27.07.2009, 23:01
So I'm ordering a replacement throttle pedal spring, since my existing one was broken, with unpleasant consequences for the pedal feel.
Having measured the remaining part of the existing spring and poked around a few spring specialists I've found a similar part, but I've got to order a minimum of five. Anybody else need one? About £2.77 each...
Adam
ashm
by Specky » Tue 28.07.2009, 09:26
I've got a spare pedal box, would you like the spring off it?
by ashm » Tue 28.07.2009, 10:12
Thanks for the offer, but I should be fine as I've ordered 5 anyway.
The spec is as follows:
Outside Diameter 12.700 mm
Wire Diameter 1.244 mm
Maximum Load 44.480 N
Free Length 38.099 mm
Rate 1.27 N/mm
Maximum Length 70.103 mm
Initial Tension 3.914 N
Material MW
Number of Coils 12.9
Finish ZINC PLATE PER ASTM B633
If anyone is interested in comparing one of these to an intact original to confirm that they behave similarly, let me know. I suspect my original will have loosened up slightly over the last 18 years, and I only had part of it to test for spring rate.
Cheers,
Adam
ashm
by Nobby » Thu 30.07.2009, 18:46
go on then, If you have one going.
cheers
Nobby
S2 #070 BRG
Nobby
by rip » Thu 30.07.2009, 22:41
I'll have one too. It's one of the few things I've not had to replace yet
by BFG in the BRG » Fri 31.07.2009, 07:49
Oh Oh,
group buy
Yes please, I am in no dire need of one but spares are always good
(Sorry about creating the list - I'm just that kinda guy)
1. Ashm
2. Nobby
3. Rip
4. BFG in the BRG
5.
Kind regards
BFG
Alas soon to be Elan-less
BFG in the BRG
by ashm » Sat 01.08.2009, 17:13
Well, they've arrived and as expected the spring was a pain to install. Still, it's in now and the pedal feels much better, even if my fingers feel much worse... it appears to be a good match for the (now unavailable) original.
Those on the list, if you pm me your addresses I'll post them out.
Since I still have a little slack in my throttle cable I'm going to need a new one. Faced with paying £37.65 for the Lotus version, complete with plasticky pedal fixings and limited adjustment range, I'll probably make up my own for about £20. Do we reckon there'd be interest in doing a batch?
Ad
ashm
by Nobby » Sun 02.08.2009, 18:29
ashm wrote:Well, they've arrived and as expected the spring was a pain to install. Still, it's in now and the pedal feels much better, even if my fingers feel much worse... it appears to be a good match for the (now unavailable) original.
Ad
Hi Ad, you have a PM
Darn just replaced my throtle cable with an original. I have kept the old one as an emergency spare.
Good luck with a group buy, £20 is a bargin so is sure to spark an interest.
Thank you
Nobby
S2 #070 BRG
Nobby
by dapinky » Sun 02.08.2009, 18:36
ashm wrote:I'll probably make up my own for about £20. Do we reckon there'd be interest in doing a batch?
Is this a good place to run a list, or will you be wanting a new thread in the Group Buys????
Ahh, what the heck - lets start one anyway.......
1) dapinky
2)
- LEC Administrator
by rip » Sun 02.08.2009, 22:54
dapinky wrote:ashm wrote:I'll probably make up my own for about £20. Do we reckon there'd be interest in doing a batch?
1) dapinky
2) rip
by ashm » Mon 03.08.2009, 09:27
Hmm... ok, I guess there may be some interest.
What I'll do is prototype a cable and test it, then find a volunteer to check it fits their car. After that I'll either make up the cables myself or have the component supplier make them if there are more than I can handle in my limited spare time.
The current plan is to use teflon lined conduit with a black pvc cover, but I could do stainless steel braided conduit as an option. Other colours of standard conduit might be available. The throttle end will be similar to stock, but the pedal end will have a galvanized quick-release clevis pin, possibly with some additional length adjustment if there's room.
I'll start a new group buy thread when I'm happy with the prototype.
Ad
ashm
by ashm » Tue 11.08.2009, 11:18
Thanks guys, hope they come in handy someday!
Adam
ashm
