Window bobins and tapping plates
Postby bobbrown » Sun 08.11.2009, 16:00
see viewtopic.php?f=8&t=16112&p=213936#p213936
tapping plates£1.00 each and bobins £4.00 each
1.
2.
3.
Pacific Blue N/A
Re: Window bobins and tapping plates
Postby Denny » Sun 08.11.2009, 16:39
1. Denny (2 plates + 2 bobbins)
2.
3.
Denny
Postby Dico » Sun 08.11.2009, 16:44
2. Dico (2 plates + 2 bobbins)
3.
Is that enough bobbins/plates for two complete window refurbs?
(Dico proving that he's no idea what he's buying but hell, its a group buy :D )
Postby Specky » Sun 08.11.2009, 16:49
2. Specky (8 Plates)
3.
Postby bobbrown » Sun 08.11.2009, 16:52
tapping plates£1.00 each and bobins £4.00 each + postage
3. Dico (4 plates + 4 bobbins) two per window
4.
Pacific Blue N/A
Postby Denny » Sun 08.11.2009, 16:57
1. Denny (4 plates + 4 bobbins)
4.
Denny
Postby nicowalker1 » Sun 08.11.2009, 19:30
whats the function of these? i have a rattley loose window on my passenger side, just not been brave enough yet to strip the door...
nicowalker1
Postby inkitin » Sun 08.11.2009, 19:31
4. inkitin (4 plates + 4 bobbins)
91 SE Calypso Red
inkitin
Postby bobbrown » Sun 08.11.2009, 19:35
When the window is up they lock into two plates on the door and act as up stops.
A rattley loose window is probably due to the failure of the brush seals on the inner/outer support pads.
I'll see if I can sort out the screws and the washer for these
Pacific Blue N/A
Postby BFG in the BRG » Sun 08.11.2009, 19:46
5. BFG in the BRG (8 plates) please (well OK I actually only need 4 but someone is bound to want to jump the list after the closing time, unless 8 is too many in which case amend to 4 - does this make sense?)
Alas soon to be Elan-less
BFG in the BRG
Postby Candles » Sun 08.11.2009, 20:47
6. Candles. Whole car set please. Is that 4?
Candles
Postby markv » Sun 08.11.2009, 23:38
7. markv (4 plates + 4 bobbins)
Postby Elanlover » Mon 09.11.2009, 23:03
8. Elanlover - full set (whatever that is)
Postby AndyT » Tue 10.11.2009, 17:59
9. AndyT (4 plates + 4 bobbins)
Not sure if I need them but I'll have a set anyway! :-D
AndyT
Postby al » Tue 10.11.2009, 18:14
Adding my interest from the original thread here too.
10. Al (4 plates + 4 bobbins)
al
LEC Bit Basher
Postby rip » Tue 10.11.2009, 18:34
11. rip (4 plates + 4 bobbins)
Postby theelanman » Tue 10.11.2009, 21:13
12. theelanman (4 plates + 4 bobbins)
Postby surfboardfiller » Wed 11.11.2009, 10:48
13. Phil (4 plates + 4 bobbins)
surfboardfiller
Postby Briggsy » Wed 11.11.2009, 20:47
14. Briggsy (4 plates + 4 bobbins)
S2 #392 Azure Blue / Magnolia
Briggsy
Postby Tyger » Fri 13.11.2009, 16:04
BFG in the BRG wrote:When the window is up they lock into two plates on the door and act as up stops.
Yeh, the plates that the bobbins fit into when the window is fully up are the primary means of adjusting window fit to the hood seal. They are only engaged when the window is fully up.
The screws are M5x 20mm, as I recall. Can even be bought in the USA! :) I think the washers are not actually necessary.
'91 Elan, '05 Elise, '90 Esprit SE ('06 Quattroporte, '01 TT MkI, '88 Daytona Shelby Z, '83 RX-7)
Tyger
