Brit-Car-Nut wrote:Pete: 3D is still pretty expensive and has a bit more grain to the final surface.
I have a friend who is waiting for me to find my original NEW set - not the cut out ones, I managed to get a pair of the originals from before the Lotus bodge solution. He makes specialty cowls for the serious model airplane world and has a really good vacuforming company that is willing to make a bunch.
Easy enough to make a production mold and knock out a few sheets of them, but knowing they are possibly the last uninstalled set in the world, I put them away somewhere to be SAFE. Now, I haven't been able to remember where that is.
I will find them soon since I am regrouping and planning on getting the body and parts painted again to reach the correct color and then will be anxiously reassembling the car so all of my hiding places will be emptied.
Older squirrels unfortunately sometimes forget where they store their nuts...
novacaine wrote:I don't think I realized how hard it would be to get hold of these little buggers.
I've managed to find these Corner Trim. I've contacted them asking for dimensions as they are not stated on the website, but they look similar
Brit-Car-Nut wrote:Getting a 3D scan or someone to draw a corner is way too expensive around where I live. I also put out feelers for someone to make a formal mold from a drawing and the 10 to 30 THOUSAND dollar estimate makes it a non-starter.
It's a friendly and helpful community.Elanlover wrote:novacaine wrote:I don't think I realized how hard it would be to get hold of these little buggers.
They do "look" similar but that means nothing really. Can't tell much from one low res pic. Someone would have to order one and compare it. If it is identical (or close enough) it would save a lot of time, effort and money trying to reproduce them. Anyone in the UK with an original piece willing to cough up a few quid to test it out???
lotos wrote:Brit-Car-Nut wrote:Getting a 3D scan or someone to draw a corner is way too expensive around where I live. I also put out feelers for someone to make a formal mold from a drawing and the 10 to 30 THOUSAND dollar estimate makes it a non-starter.
http://makezine.com/maker-community-groups/
That's a short list, there are lots of Maker groups out there that offer shared time on scanners, 3d printers, mills, etc. They often offer super discount prices to use something like a scanner, which uses only time (no materials) to get it's job done. Heck buy a 3d scanner owner a beer and it might be good enough to get it scannedIt's a friendly and helpful community.
novacaine wrote:Once they get back to me with the dimentions, if they are similar I will buy a couple to compare with my slightly cracked ones
lotos wrote:John - I'm afraid I may not have explained myself very well. There are lots of small groups - including in the Carolinas, that work together to help each other. They even do big Maker Faires in Raleigh, so you can be sure there's a vibrant DIY maker community alive near you. There's also a group I found in Burlington, I'm not sure where exactly you are located.
These aren't corporations -these are people who shelled out $3k for a 3D scanner and are willing to let others use it. Same with 3D printers, mills, and sometimes just a helping hand. It's a new concept you would be forgiven for not knowing about, it's all a new frontier with the DIY-grade equipment starting to rival the professional stuff. Makerbot has an entry level 3D scanner for like $750. High end ones like the NextEngine are a few thousand but increase the scanning resolution substantially.
Anyway, just some stuff I've learned about that may or may not be useful to you with this or any project! If not, all I've wasted is a few mAh on my laptop typing this up
Elanlover wrote:Makerbot's 3D scanner.
http://store.makerbot.com/digitizer
I wouldn't suggest using a 3D printer to make up the corners. I don't even know what their composition is and if a printer would support the materials. However, the scanner is useful for any small scale scanning projects. What I don't see on their website (although I'm sure its there somewhere) is the resolution supported and if the scanner spits out standardized files or if they are proprietary to Makerbot's gear.
EDIT: these specs are at the bottom of the page. The resolution might not be enough for this piece. These guys make a higher res model.
