OK, so I seem to be having pretty much the same kind of problems but I'm not sure how to resolve them. ElanScan keeps telling me inactive Com port, bad echo etc and no data appears.
1st I'll assume I've got the basics right - laptop with WinXP; ElanScan (0.9.9.61) running and appears normal; there's only on f in Geof Smith's ALDL interface cable with USB; VCP driver files CDM 2.02.04 WHQL Certified from
http://www.astb91.dsl.pipex.com/VCP.zip per notes from forum (
http://www.lotuselancentral.com/forum/v ... &start=280)
and the ALDL interface cable socket attached to the plug removed from the firewall socket located behind the glovebox just above the ECU box; key in ignition switch, ignition fully on (immobiliser off) tried with engine running and not running.
Checked WinXP Control Panel>System>Hardware>Device Manager>Ports (COM & LPT)>USB Serial Port (COM12)>Properties
this is what it says in the 'tabs'......
General - USB serial port (com12) Device type: ports (com & lpt)
manufacturer: FTDI Location: on USB Serial Converter
Device Status... This device is working properly.
If you are having problems with this device, click Troubleshoot to start the troubleshooter.
Device usage... use this device (enable)
Port Settings
Bits per second: 9600 Data bits: 8
Parity: none Stop bits: 1
flow control: none
+++Advanced settings Com port number com12
usb transfer sizes:
Receive (bytes): 4096 Transmit (bytes): 4096
BM Options Latency Timer (msec): 1
Timeouts
Min read timeout (msec): 0 Min write timeout (msec): 0
Miscellaneous options: serial enumerator [checkbox: ticked]
Driver
USB serial port (com12) FTDI Ltd ver 2.02.04 [2.2.4.0 27/06/2007]
Details: device instance id: FTDIBUS\VID_0403+PID_6001+ELANSCANA\0000
hardware ids: FTDIBUS\COMPORT&VID_0403&PID_6001
Elanscan software set to read com12.
I think it's a 'timeout' / 'latency timer' kind of problem or maybe a baud rate thing, but then I'm just a dummy. Does anyone else have an idea?
