Elanlover wrote:Is this a fit for the Elan though? I understood that Lotus moved the turbo housing from Isuzu's OEM design. If its a direct bolt-on then it might be interesting.
Elanlover wrote:Not precisely but the first pics you've shown don't look anything like the last pic. Look at the outlet positoning. Although, you didn't say if your first pics were of the actual Isuzu piece or just a representative pic of their work in general. Some links to review the product would be helpful too.
Elanlover wrote:Not sure I'd want to mess around with the turbo plumbing to make that fit although I'm sure a talented person could do it. Lotus moved it for a variety of reasons including performance (the closer to the exhaust manifold your turbo is the better). The current manifold run is so short as it is I'm not sure there'd be that much benefit to a tuned manifold. Plus, with the engine bay being so cramped there might not even be room for the bulkier pipes running off the manifold.
I say Jet-Hot coat it
F1 LOTUS wrote:It should be much lighter than the cast iron lump, ceramic coating could reduce lag? It will probably crack after a relatively (compared to stock) short time? IIRC the stock turbo and fanimold weigh 37 lbs
F1 LOTUS wrote:With the new manifold turbo speed-up grew by 500rpm.
As a bonus, spoolup has been lowered by 500rpm.
geoffsmith wrote:F1 LOTUS wrote:With the new manifold turbo speed-up grew by 500rpm.
And if you press the |English| button rather than translate the French, it says:
But isn't spool up a measurement of time in seconds?
Daave wrote: as the original manifold looks like it would be a restriction above 300bhp IMO.
