Elanlover wrote:I think Monty was able to fix this the same way he fixes all his problems.....with a knife (tee hee).
don`t forget the drill
Don`t know why lockwood didn`t match up the locating holes
surferphil wrote:I saw the Metal Monkey dials on Nige's car and thought they look really nice.
But made from slabs of steel!How silly.
Nige wrote:surferphil wrote:I saw the Metal Monkey dials on Nige's car and thought they look really nice.
To be honest they are so thin they must weigh at least 5-10 grammes more than the plastic originals or the Lockwoods.
Anyway Phil thought you would have had a state of the art multi function display by Stack or the like in there, one dial to do everything seems like the best weight saving option to me.
Candles wrote:There is SO much wire kicking around the car for speakers, alarms, seat belt warnings, washer bottle warnings etc etc. All you need is a big tacho, which is one wire from the ECU (already fitted) and will work out of the box from the gauge company!
If you do want a speedo, I have a VDO GM hall effect sensor in the gearbox speedo drive, and that drives an Autometer speedo, again via a wire.
Candles.
surferphil wrote:The Lockwood set should come with adhesive washers that fit under the needles (to block out the light). The kit is actually shite; the holes don't line up with the locating lugs on the unit. I had to take the smaller dial needles off to fit the faces and then had to bodge the fitting so the needle points to the right part of the face as the rev range is completely different.
The dials are obviously for a different car and rebadged as 'Lotus Elan' dials. I contacted lockwood about this but like most companies who produce poor products - no response. I suppose you get what you pay for £28 is perhaps too cheap for a quality product. Its a shame as they look quite good; they just don't fit the Elan SE.
I'll see if I still have the instructions but they are not good.
Elanlover wrote: As Monty said above tough, a drill bit can make them fit.
surferphil wrote: It doesn't change the rev range though so the dials don't actually match!
Bolsom wrote:Having just bought the main dials from Mattdon with Vauxhall fitting instructions and now read this thread through. Would anyone be kind enough to email me a scan of the Lockwood fitting instructions please. I can't see how you can fit the dials without removing the needles other than by cutting a slit at the bottom of the dial by the needle. The needle mounting looks larger than the hole the shaft goes through. I guess I will also need to fabricate some adhesive washers fit under the needles. I want to be as clued up as possible before I attempt this fiddly job.
Colin
Paul.P wrote:
The rev counters were identical to the originals, but the speedo only read to 160mph ( lotus 170mph ), but we had proved that with 16" wheels the speedo actually was more acurate.
Elanlover wrote:True. The MM dials match though as they were based on the OEM markings and have the proper redline of 7200 rpm marked as well.
